Decided to wreck my R33 Skyline, no engine, no diff, no gearbox.
Many parts available, price list below. If you see something in the pics I haven't listed let me know.
Might have other bits and bobs, if you're looking for something specific let me know.
1. Power steering rack $150
2. Brake cylinder $80
3. Origin 20mm front guards (passenger side has a 5cm crack from tyre hitting guard) $220
4. URAS front bumer $100
5. OEM power mirrors $30 each $50 pair
6. Series 2 front seats and rails $60 each $100 pair
7. Series 2 wing $50
8. taillights $60 each $100 pair
9. headlights $80 each $150 pair
10. OEM rear bumper $50
11. Stagea rear subframe $120
12. stock fuel rail and injectors $40
13. RB25 Altenator $50
14. Starter motor $50
15. OEM throttle cable $20
16. Door, $120 each $220 pair
17. Bonnet with bonnet pins $120
18. Nismo clear side indicators $50
19. Japan boss kit $60
20. Ignitor $50
21. wiper motor $50
22. East bear (GTR type) front grille $120
23. bootlid $100
24. Skyline rear garnish $50
25. Antenna $50
26. Battery $50
27. aftermarket cluster, white LED's installed $120
28. R34 GTR front indicators $40
29. Most boot trim $50 the lot
30. Various interior trim, let me know what you're after
Will ship at buyers expence, located in Liverpool region.
PM me!
Adam.
https://www.sau.com.au/forums/topic/408510-syd-wrecking-r33-2-door/
Do you have the out side b-pillar plastics? Both sides. " the little/ long plastic bit between the front and qourter panel window" message me on 0410717935 or pm me on here please need them ASAP
Nissan S15 throttle cable
Perfect length for forward facing plenums
$60
3 Inch resonator
Brand new
$30
Billion/ASI silicone radiator hoses
Billion top radiator hose, allows fitment for water temp gauge
ASI lower radiator hose
$80
Edited by Run-It-Hard
Are those Series 1 front seat belts?
if they are do they sag at all (my series 1 don't want to retract)
Yep It's a series 1.
Not that I recall, the backs used to do that but the fronts are fine :)
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
