Hey, you know how Turbo is illegal for P Platers in NSW. Is there a way to get the engine modified to have the turbo's underneath or in the middle of the engine, or some place where they are hidden and if a copper looks inside the engine they can't see them?
https://www.sau.com.au/forums/topic/408513-turbo/
Yeah, remove the sump, fit the turbo in there and re-fit the sump and no-one but you will ever know its there
Remember to re wire the turbo to the air control unit otherwise it will leak fluid and the cop might see that.
But yeah do this!
Cheap as well it's about $250 from what I remember when I did it on my P's
https://www.sau.com.au/forums/topic/408513-turbo/#findComment-6517713
Hmmmmm... I remember this guy
But for serial, mount turbo in wheel arch.
They never look there.
Oi zeb, Ill be around to help with the turbo install, did you get your relocation kit?
Just unloading the container now, should be in here
https://www.sau.com.au/forums/topic/408513-turbo/#findComment-6517778
You ask a question, people answer, then you get upset at them. They even gave you the answer you wanted, yes it's possible, via any number of ways. your only other option is to remove the turbos all together and run an NA ecu until you are on your open licence, but you will lose performance.
https://www.sau.com.au/forums/topic/408513-turbo/#findComment-6517843
I would do this, much less effort. Ask Benji "Bakemonoricer". He's also good with rotary head gaskets if you ever go down that road.
https://www.sau.com.au/forums/topic/408513-turbo/#findComment-6517858
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
