hi fellas, my 26 was running like a bag today,ive only had it about 2 months so havent driven it a heap...anyway it has been sitting for a couple of weeks but never done it before. im thinking it could be shagged plugs or coil packs but really have no idea ! i was playing with the 2wd mode by turning the car off and rolling and turning her backk on.. dunno if that could effect it in anyway... what it was doin was running fine one minute and coughing and farting the other, i cant remember if i was into it or not...was like hitting rev limiter at like 3000rpm and not going above that if you rev it. also wouldnt idle. it was playing up as i rolled into the servo, switched it off got some fuel, started it back up and ran fine. if anyine can give me some info that would be awesome. thanks
https://www.sau.com.au/forums/topic/408516-32-gtr-running-roughsometimes/
Coil packs would be my first guess, pull the cover off the coils and let it idle at night, you will probably see the sparks coming off the coils out onto the cam covers. If not possibly ignition timing moving due to damage on the front of exhaust cam. Try the coils first IMO, but there are others who know better
i dont think so, it done it before and after i got fuel mate, it just seems electrical to me, not like an old carby car where they cough and fart. like when i was trying to rev it and it was going from 2500rpm to 3500 rpm like a slow rev limiter. but it didnt just do it between that rev range ran like a bag lower than that too. im going for a drive tomorrow incase it was shit or dirty fuel but still seems sus/electrical to mee.. thanks!
I don't think it will be timing moving based on that, but to check it, put a plug lead between #1 plug and coil, check the timing then turn it off and start it check it again. See if changes drastically.
thanks iplen ill try that,if only i was closer haha and pipster i was thinking afm's after reading some info. i did have it all pulled to bits to paint some things, maybe i got some shit on the inside of the afm sitting in the shed?? . i checked the plugs into them when i was on the road and they were in firm, if she does it tomorrow ill tell u boys and try to describe it better, also might contact clean all the plugs i can get to. thanks again!!
grab some brake cleaner and a soldering iron!
hit the element with the brake cleaner and then solder up the bad joints!
maybe do the soldering first tho, brake cleaner is quite volatile
hi fella, well i think i sorted it, and it was the bov leaking!! im 90% sure, so all that minf f@ck for something so easy! also soldered the amf's but as i said recon its the sneaky lil bov!! had to let use know!! thanks
how did u know bov was leaking?
hi mate, well i put my hand over the (air to atmosphere) pipe and the car changed revs at idle.. and i stripped the bov in 2 seconds and found it wasnt sealing when shut, plunger was shagged so i clogged up the hole and she ran awesome :)
How much fuel is left in the tank when this happens, 1/4 by any chance?
I thought so, empty around 1/4 tank means you have a aftermarket pump in there which isnt mounted properly (either a bosch 040/044 or a walbro 255)
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
