AAAARRRGGGG.
Best run was 12.105 @ 126 mph
I missed gears ( 2nd to 5th is not a good thing), still stupid amounts of wheel spin, I then was given the good word to start in second which would have worked better with more revs as I stalled launching off the line.
I eventually got a good run on my last pass, started in 2nd, launched at 6000rpm, it felt good till I got some wheel tramp, still it was my best launch and time.
My next time out should be better still as Im starting to get the hang of it, I just need to slip the clutch a little longer instead of getting off the throttle as I think this is what caused the wheel tramp.
Over all a fun night.
11.99999999999999 next time maybe !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
At least Nick had some good times.
Mark, how'd that last run feel, it looked better, no stall at least :nyaanyaa:
bit slow off line then some wheel spin then gone
Thanks for the tips mate, Im sure with some more seat time Ill eventually get there.
Ohhhh Mark soooooo close!!!!
I had abit more luck then Mark first run was an 11.9@118mph I was stoked with that then 2nd run punched out an 11.622@119mph
Got close to it with an 11.67@120 then 11.7 and an 11.8
For some reason boost wouldn't go above 1.4bar when it should be 1.55 so confused about that one but all in all car performed flawlessly and very happy with the results
Tyres used were 265/35/18 Michelin pilot super sports
that's it mate, more practice and that 11 will come, you have good mph
do you think the second gear launch was better traction wise and with a few runs more do you think it will work for you
60" time on the last?
The 2nd gear launch felt much better BUT the 60 ft was 2,347, the wheel tramp put me off as it gave the car a good shaking at the top of 2nd gear, I thinkl I backed off a bit and it started to tramp, I should have kept up it in hindsight, time will tell.
Did it look like I had the right revs on launch?
yeah it looked much better, to me it looked like your clutch motion/timing was a bit off though, bit slow to get to the friction point then a bit to fast off the rest, which results in rolling off start line for a few meters then excessive wheel spin, your car clearly has the torque to pull second no worries it's just practice, and 6000rpm in second looks the money
maybe look at slightly stiffer shocks, your squatting a bit fast and it looks to be hitting the bump stops
well that's 3 beers time for bed
So close mark, let us know when your heading out next.. Hopefully when I'm back!
Nice work Nick, what power is your car making now?
Making 350-360awkw that's at 1.55bar tho was only for some weird reason making 1.4bar tonight so say 340ish tonight lol who knows :P
Im going next week :) lets see if i can get a 11.5 this time.
Nick ma man. Need to nail those 60' times man
Even with your "low boost" thats a low 11 sec car
Yea probably had wrong tyre pressures not too mention the circuit set up I'm running but still very happy with the result
And my ham fisted driving hahahaha
Lap times are what I'm after ;)
Time to get yours out on track!!!
I agree Nick you need to work on your 60's. Back in the day (before my flywheel turned to dust) I was doing 1.6's on worn out Nankangs with less power. You have a solid 0.25sec ET to gain just on improving your 60's.
Yea you are right im sure with some more practice i could get it alot lower but for me anyway straight line gets a little boring
dont get me wrong its good fun but not what i built my car for
It's great practice for the track. Gear changes and throttle control play a big part in 1/4 mile and show massively in your ET. Transfer those skills across to a 2-4km circuit and you can see how much time can be gained/loss just in gear changes alone.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
