Hey guys, I have a rather weird boosting issue with my car.
Car would run/boost fine, then all of a sudden it would run weird and won't boost past 6psi. I shut the engine off for about 5 seconds, fire it up, runs fine, then after a while (5-30 minutes, no certain interval i.e. random), same weird issue.
During this 'boosting problem' mode, as soon as the car goes above 0psi, it will surge and run rich. On overruns/shifting, it will dump fuel (exhaust makes cool popping noises).
Shut engine off for 5 seconds > fire it up > runs fine.
Sometimes it will run fine for over an hour. Sometimes it will happen after 5 minutes.
This issue occurs when the car is warm.
Perhaps AFM(s) is playing up, unable to afford a new pair of them unfortunately. Still doesn't explain why it won't boost past 6psi (or 350mmHg or 'halfway between 0 and 7' according to standard boost gauge).
Any ideas/experience?
https://www.sau.com.au/forums/topic/408592-strange-boosting-issue-r32-gt-r/
Yeah hesitates. Can't hear anything else though.
With the vac leak, why does the issue always disappear if I shut the engine down and fire it up after 5-10 seconds? That thing stumps me. Friken car, just more problems (HICAS flicker issue still there as well, definitely electrical).
I'll have to pull the crap off to fix exhaust leak anyway (not related as issue was present before the leak... I think).
Does sound the the AFM's then unfortunately... there are some tuners who can patch them up... I know the guys at RE Customs down here did for me and haven't had an issue since...
Worth taking a look maybe?
I'd say it's your afm's. Try driving over pot holes and if it happens everytime you hit a pot hole then it's most likely dry solder joints on the pins in your afm's. Easy fix.
My car was doing it for a while. Took it to 3 different places and they couldn't find the fault.
Sounds electrical / AFM.
Start by cleaning them, grab some CRC mass air flow cleaner from super cheap. Check and clean your connections as well.
If no luck, then go down the repair / replace path.
Just thinking, depending where you are located, maybe there's someone nice on here that can lend you some AFM's to test before purchasing?
Edited by iwanta34gtr
Ooops forgot to follow this topic. Thanks for the offer BWRGTR, I might have to take it up.
I got a pair of AFMs from Brisbane (apparently they were R33 but has R32 written on them lol). Chucked them in this time last week, car ran awesomely. The frequency of the slight miss on idle was reduced, car ran smoothly and boosted to 12psi without issues.
This morning, the problem reared its ugly head again! WTH!? Although the performance degredation wasn't as bad as before, it wasn't going past the 3/4 boost mark (~350mmHg) and hesitating/being lethargic. Shut the engine down at a set of traffic lights, fired it up and it ran good again.
At least on my R31, I just wiggle the AFM plug a bit and it runs good lol. This car brings much electrical headaches.
I'll have to look into doing a solder fix on possibly this or my old pair of AFMs and seeing how they go... Unless someone has a good pair of known fully working AFMs (BWRGTR?) hahaha.
Cheers guys.
    • Dang I looked at this for so long until I realised it was for the inner rod. I was so confused. This looks like a great tool. Another injected plastic box for my collection. I for one am a torquer. I'm far too anxious and neurotic to not use the correct torques whenever I can. I do honestly feel like my wheels will fall off if I dont.
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
