Hi all,
After a bit of advice on a head that I sent away to have some machining done on. The head has passed a pressure test ok but the combustion chamber appears to have a couple of cracks between an inlet and exhaust valve on cylinders 5 and 6. The engineering company have ground away the surface a bit to check to see if it was a surface crack but it appears to go deeper as shown below :
Frankly, I spent ages porting the ****ing thing before sending it away so is it repairable or ?
Edited by mambastu
https://www.sau.com.au/forums/topic/408616-cylinder-head-cracks-repairable/
To repair it you'd have to gouge it all out, bake the head to remove impurities, and weld the entire affected area up, provided it was even possible, then you'd have heat effected area near weld, then you'd also have stresses built in to it. I wouldn't be keen on repair.
It's a shame you're in the UK, because if you were in Aus I'd suggest sending it to someone here in Adelaide that could pretty near build you a complete new head out of welding rod. FWIW, that head looks completely repeairable, but you'd need to find someone trustworthy to quote on it, because you're going to have to balance the amount of work and money required to pull the seats and guides out of those chambers and do all the prep, weld and refinish against the amount of time/money/effort you have otherwise sunk into the porting and anything else done to the head.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
