DRIFT ATTACK IS BACK!
Jam packed with drifting goodness all in one weekend, $11,000 in cash and prizes
Saturday/Sunday September 29th/30th
Calder Park Raceway
Keilor
Victoria
Highlights of the weekend include:
• Top 32 Battles for Pro Class
• Top 32 Battles for Street class
• Round 3 of the GKTech.com.au VicDrift Championship
• WOT Hobbies RC Drift Challenge
• GripShiftSlide.com presents the JDMST Show and Shine on Sunday from 12 -4pm
• Trade Stands
• MC Mozza will be on hand to keep the crowd entertained
• Crowd Giveaways
• Promo Girls
What’s at stake ?
Luke Jacobs/Nathan Charles Sportsmanship Award
Pro Class 1st Place - $3,000 CASH
Pro Class 2nd Place – Car trailer valued at $2,000 courtesy of Road King Chassis
Pro Class 3rd Place - $1,000 CASH
Pro Class 4th place – Sponsor Prize to the value of $200
Street Class 1st Place - $800 CASH
Street Class 2nd Place - $500 CASH
Street Class 3rd Place - $250 CASH
Street Class 4th Place - Sponsor Prize to the value of $100
Top Qualifier Pro Class - Sponsor Prize to the value of $200
Top Qualifier Street Class - Sponsor Prize to the value of $100
Round 3 of the GKTech.com.au Championship
1st place - $500 CASH + $200 GKTech.com.au Voucher
2nd place - $250 CASH + $100 GKTech.com.au Voucher
3rd place - $150 CASH
GKTech.com.au VicDrift Championship Winner - $1,000 CASH + $600 GKTech.com.au Voucher
This is a competition day, with an emphasis on qualifying and battles. The beginners section will be closed, this is not a standard practice day.
Spectator Fee:
Adult - $20/day
Kids 14 and under - Free
Driver Fee:
Pro Class - $339
Club Class - $239
This fee also includes 2 x Pit crew into the event also(No further pit passes available)
Pre-Entry is compulsory at this event.
Please follow link to register
http://vicdrift.com/...=com_dtregister
Acceptable Licenses are: AASA or CAMS L2NS - No license means no going on the track! (Please organise prior to the event)
Please note : VDC board members will be checking AASA and CAMS licenses. Please ensure all your licenses and memberships cards are valid.
Please visit http://www.vicdrift.com/driftattack for more info, as there is a link to the Supp Regs for the event which contains the event timetable, class restrictions and scruterneering guidelines
Don't miss out, on what is shaping up to be one of the biggest drift events in Australia !
https://www.sau.com.au/forums/topic/408623-drift-attack-2012-at-calder-park/
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
