Sau Vic 2012 Motorsport Championship Round 7 - Hh 13Th Oct
Yes the silver gtt. I really like this track like a compact winton more handling less power.
I was fighting understeer most of the day as were others, up hill brake and turn sections were tricky.
After doing hh then rocking up for maserati I'm in (+ my car's in) recovery mode atm.
  • Replies 111
Posted Images
Ah yes met you at Sandown! Good times!
nice.
Not that it is going to make a huge difference for this year but what mods do you ahve so I can put you in the correct class?
M
Keen to find out so I can compare times! ;)
You know sandown/pi terrifies me more than hh, I think it's the speeds involved.
I've been looking at richo's sandown vid and see I have to brake deeper and hold higher speed into turn 1 and back kink - both another 10kph higher - easier said than done.
Car has a gtx3071 .63 iw, 3" exhaust + metal cat, ~235rwkw, coil overs, standard sways and brakes, 6 point cage.
After sandown I now have a "new" shriek after 5k rpm to investigate, probably a leak or crack in exhaust somewhere.
Also noticed once again the hot weather stuffed my tune so had to pull some timing on sun as well.
Always something to work on or improve.
Talking of delays, currently working 6 days a weeks, so with work, family, household chores etc only just got around to reviewing footage.
Anyhow thought I'd fill in the gap between events with this clip, so what is this about Haunted Hills being a track for a decent driver in a well sorted chassis :)
Is it just my work computer blocking content... or are you missing a link there bloke?
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
