Membership forms for the club (also required for my CAMS licence application) where would I aquire one of these mofo's? :)
http://www.skylinesaustralia.com/forums/topic/349895-so-youve-never-done-texi-before/
A bit of the information needs updating actually... Don't take it all as 100% gospel, but the form is in that page :)
  • Replies 147
Wouldn't be surprised if the old super taxi's knock a few out this round but it means more track skidz for those that do come along. Tape the race and come out then go home and watch it - winnar!
Also, the execs have also been working on a new club point score so this event will be the first to get you points in our fun club point score.
More info on this coming out VERY soon.
This will be the first Texi, EVER that I will miss.
I'm happy to say I've never missed one up till this point :)
OMG! OMG!
It's ok Steve. I've got this covered and will be the barking dog getting everyone in ship shape. Aggro you gonna be my back-up, right?
just emailed off entry form and recept.This is my first time and was just checking if anyone from Newcastle was going ?
I was planning to head down and lend a hand... Will let you know later in the week...
Lol car wont be getting a hard time, dont wanna sping a bearing gotta make it to the nats..
ooooh i'm sorry Luke :P hahaha
all good, if you can't have a laugh about it, you need to lighten up.
I think were ok....
Might be important to note: This Is the first day of daylight savings..
You loosean hour!!! what you think will be 7am will in fact feel like 6am. (cause it really should be if clocks didn't change)
Scrutineering/sign on starts 7.00am
Scrutineering/sign on ends 8.30am (don't show up at 8.25am, come with plenty of time to spare)
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
