Hey mate do u still have spots left? This will be my first one can i get a cams licence on the day?
Yeah mate still plenty of spots left, You can organise CAMS or AASA licence on the day, just bring $50 for AASA or you can $109 for CAMS L2S, $60 for L2NS or youdo direct debit for cams
Might be important to note: This Is the first day of daylight savings..
You loosean hour!!! what you think will be 7am will in fact feel like 6am. (cause it really should be if clocks didn't change)
Scrutineering/sign on starts 7.00am
Scrutineering/sign on ends 8.30am (don't show up at 8.25am, come with plenty of time to spare)
good man!
  • Replies 147
so just bring 50 on the day so i can do it? lol so ill just pay the fee through direct debit for the actual day? So all up should it be 79 for the day and then bring 50 on the day? Sorry with all the questions just new to it all lol
You loosean hour!!! what you think will be 7am will in fact feel like 8am. (cause it really should be if clocks didn't change)
FYP
FYP again
cams have a direct debit for their licences thats all I was saying.. ie fill in form with CC details, we send it and they take money when they process it.
your entry fee needs to be paid beforehand into the SAU account if possible otherwise you will need to bring cash for the amount relevant to your entry. Ie whatever first timers cost
its like im speaking spanish or something
OK people spots are filling up, so please DO NOT wait until the last minute to enter this! The event has been posted in a few different websites and forums and it is generating a fair bit of interest because lots of people have heard about it and are keen to see what all the fuss is about.
And yes, Day Light Saving starts that morning, so you will lose an hour of sleep. Please don't forget to factor this in when going to bed the night before!
F in the A, I was going to do my first texi, I took car to get looked at & turbo has issues, now my almost completely ruined clutch wont get the death it deserved....
So disappoint.
Dude that sux...... Sorry to hear! You can still come and watch others ruin their clutches! Hehehe
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
