  • Replies 103
Are they both using the same turbo's?
Obviously if a turbo is at the edge of its efficiency then a set of cams will do wonders, cams reduce the amount of boost required to flow x amount of air.
To make more power you can either use a larger laggier turbo or start looking in to improving air flow in to the pots.
No, there not using the same turbo, I have a GT30, and robs is the TD06. Even he will agree that his is laggier than mine.
The point that we were trying to make is that SK comment
My experience has been that the standard camshafts are the most likely first limiter over 250 rwkw. They simply don't have enough lift or duration to let the air into the engine. Sure you can turn the boost up and try and squeeze some more air in, but you will get higher inlet air temps and lower efficiency.
doesn't always hold true. On stock cams mine has made 330rwkw and still hasn't fallen off at 8000rpm. That's not to suggest that most RB25's don't do what SK suggests though, but cams may not be the only restriction.
I haven't had any port work done yet. just want to see how far I can go with the stock cams.
and its still using standard injectors and cams?
We're using GTR injectors now, although we could have got the stockies to this level, we knew that seeing as we're pushing for 500rwhp that they wouldn't last. Just need to fit an 044 pump as I'm sucking the pump dry:(
GTS-t Vspec,
You are definately missing out on not having some higher lift/longer duration cams in your engine. You will make more power and the inlet temps will not be as high, it's just physics. There are always two ways to make good power. So far you have chosen the hard way trying to see how much power you can make on standard cams. For the rather small outlay you could pick up so much performance. I'd like to see you crack a 12 second pass, you've been waiting so long for it so I reckon you should treat yourself to some nice camshafts :P
GTS-t Vspec,
You are definately missing out on not having some higher lift/longer duration cams in your engine. You will make more power and the inlet temps will not be as high, it's just physics. There are always two ways to make good power. So far you have chosen the hard way trying to see how much power you can make on standard cams. For the rather small outlay you could pick up so much performance. I'd like to see you crack a 12 second pass, you've been waiting so long for it so I reckon you should treat yourself to some nice camshafts :(
Dave, Sure I could put a set of cams in, and make alot more power, but I just wanted to show that it's not necessary to make decent power and not run out of puff at 6500rpm. I'll do an 11sec pass with stock cams just for you;)
You go for it, it's not the way I would do it. But hell, give it a go, maybe you will be the first person in the world to do an 11 on standard cams. :( I really don't know whether anyone else has ever done it. I do know a black R34 GTT that did an 11.6 with 50 bhp less than you. But it had 260 Tomei Poncams in it, so it doesn't count.
But on to more serious matters...
the engine had only been rebuilt 2 days earlier
What happened?
I have no doubt of its potential.
I cant pull on it with 4 people in my car yet i can easily walk away from other reasonably quick cars(low 13's etc) as if they standing still.. once again with a full load.
What speculation you want on his HP.. if you'd see it you'd believe it.
THing is Sydneykid is we have cars out there,You rewrite other PPLs storys as your own.
Facts Steve, I only deal in facts. And the fact here is the R34 GTT did an 11.6 with 50 bhp less. Whether I wrote the story or someone else did is irrelevant.
i seem to recall use of slicks.. and bits breaking..
Yep summoner 50% correct, my suspension set up got the traction and squat so good that a driveshaft became the weakest link. But the fastest run was on Nitto's, not slicks.
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
