Hey guys,
Looking at selling my pride and joy of the last 5 years...
Due to getting a side job im needing a ute and got a young family that will probably grow in a few years, need a car that i can chuck all the gear in and go out with the family in.
I purchased the car in totally stock form.
Mods so far...
-Nistune Computer fitted and tuned by Envy imports at brookvale. made 221kw atw on their dyno , didnt get a photo or print out.. got a photo at 216kw
- Just Jap oil cooler and relocation kit. Oil filter now located infront of radiator, easy access compared to the factory location!!
- Just jap FMIC
- Nardi copy steering wheel
- D1 detachable hub for steering wheel
- Boss kit ( got off a fellow sau member, is genuine Boss tho)
- Cusco 6 point bolt in roll cage, padded all round
- Fire extinguisher mounted to rollcage
- Splitfire coil packs
- Cusco brake master cylinder stopper - Not fitted but included in the price
- Whiteline Front and rear sway bars, got them from Daleo on the forum as appart of a Group Buy
Front BNF22X 27mm Non adjustable
Rear BNR11XX 24mm Motorsport adjustable
- OS Giken 2 way diff, with the OS Giken oil 80w250 grade aswell, this stuff is expensive around $80.00 per ltr!!
- Drift works Solid Diff bushes
- Driftworks Solid Metal subframe bushes
- 5% window tint all round, installed by Unique window tint, one of the best tint people in sydney
- Optima red top battery 800cca
- Battery to boot relocation
- Isolation switch in engine bay
- Hicas Lock out bar
There are probably things i have forgotten, but ill add them on as i come accross them!!
Car has 88,000 kms on it
$22,000
If you have any questions please post up or PM me..
Can be contacted on my mobile 0424 703 213, if i dont answer send me a txt and ill get back to you asap!!
Enjoy!!
https://www.sau.com.au/forums/topic/408677-fs-r34-gtt-2000-model-with-mods/
Hi Mick,
I sent you several PMs regarding something else, could you please respond to me when you have the chance?
Cheers,
Johnny
Edited by johnnilicte
  • 2 months later...
  • 3 months later...
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
