Hi, I'm a bit new. I have a couple of questions:
I have an R32 GTST, does it have front and rear camber adjustment from the factory? If so how much roughly (i know it wont be alot).
If it does where does it adjust from?
I had a quick search (in google and the forum itself) but couldnt find anything.
I am planning to buy front and rear driftworks camber arms but just scraping up the last few dollars and cents and trying to avoid scraping wheels and tyres in the mean time.
Cheers
https://www.sau.com.au/forums/topic/408687-camer-adjustment/
No front camber adjustment. You can buy offset bushes to go in the inner and outer ends of the stock arms that will gain you a little (enough for street) adjustment (and also be much better than the squishy liquid filled rubber stock bushes that are probably stuffed anyway), or you can buy adjustable length arms of various sorts that can give you more adjustment but are not all street legal.
The rear uppers have a tiny amount of camber adjustment available stock, but again your choices for improving on that are the same as above.
You need to be able to correct excessive negative camber at the rear that results from lowering. You need to be able to add camber to the front to improve corner grip. More important than adding camber at the front through (in my opinion) is adding extra caster. Caster gains you more dynamic camber in turns without the extra tyre wear caused by having high static camber. Same path here - adjustable caster bushes or adjustable length replacement arms.
Yep I am buying camber arms, and already have rose jointed castor rods.
My situation is i have 18x8.5 front and 18x9.5 rear wheels both +38 offset the fronts have 235/40s and the rears have 245/45s. I want to lower the car but worried about scrubbing as the rears sit out of the guard by 20mm approx, i want to add negative camber for handling and for the wheels to not scrub and just for a nice stance. So basically i want to add as much neg camber as possible til i get my camber arms, i am also getting the guard lip rolled.
There's downsides to too much neg camber - are you happy to live with them?
IMO basing alignment settings on looks or to address rubbing is sacrilege, but each to his own. I prefer to go fast than look pretty (also, i'm never going to look pretty so its not like i have a lot of choice)
Mike, i was thinking the same thing.
I have standard wheels in case of defect but i would like to avoid defect, its only a weekend car anyway.
I'm hoping to find a good balance between the correct camber for performance and also for looks. I want my car to be a good balance between form and function.
Thanks for all the help and ideas/suggestions
20mm is quite alot! you'll need majorly stretched tyres, prob more a 35 & prob over 4 or 5 degrees camber, both of these are illegal over here, or guard work or wheels that fit
One last thing, how do i adjust tge standard camber at the rear? Sorry if its aleeady been covered
There are eccentric bolts as the inner ends of the upper arms at the rear. But they only give a smidgin of adjustment. Not going to really get you anything. And as I said, generally when you lower a Skyline you get too much neg camber at the rear, and you want to dial it out. If you carry a lot of neg camber then you get ridiculous tyre wear, very poor straight line traction (both accel and braking) and unless you are actually really hooking into corners and loading the outside type, poor lateral traction as well. If you do and have all that just to fit excessively wide wheels and tyres, then you need a straight jacket.
I'm going to roll the lip, keep the stretched tyres and add some camber, hoping I'm not going to need more than about 3 degrees of camber. If it ends up affecting performance too and tyre wear too much I'll get different rims down the track. Thanks for the input and feedback etc
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
