Hi, I'm a bit new. I have a couple of questions:
I have an R32 GTST, does it have front and rear camber adjustment from the factory? If so how much roughly (i know it wont be alot).
If it does where does it adjust from?
I had a quick search (in google and the forum itself) but couldnt find anything.
I am planning to buy front and rear driftworks camber arms but just scraping up the last few dollars and cents and trying to avoid scraping wheels and tyres in the mean time.
Cheers
https://www.sau.com.au/forums/topic/408687-camer-adjustment/
No front camber adjustment. You can buy offset bushes to go in the inner and outer ends of the stock arms that will gain you a little (enough for street) adjustment (and also be much better than the squishy liquid filled rubber stock bushes that are probably stuffed anyway), or you can buy adjustable length arms of various sorts that can give you more adjustment but are not all street legal.
The rear uppers have a tiny amount of camber adjustment available stock, but again your choices for improving on that are the same as above.
You need to be able to correct excessive negative camber at the rear that results from lowering. You need to be able to add camber to the front to improve corner grip. More important than adding camber at the front through (in my opinion) is adding extra caster. Caster gains you more dynamic camber in turns without the extra tyre wear caused by having high static camber. Same path here - adjustable caster bushes or adjustable length replacement arms.
Yep I am buying camber arms, and already have rose jointed castor rods.
My situation is i have 18x8.5 front and 18x9.5 rear wheels both +38 offset the fronts have 235/40s and the rears have 245/45s. I want to lower the car but worried about scrubbing as the rears sit out of the guard by 20mm approx, i want to add negative camber for handling and for the wheels to not scrub and just for a nice stance. So basically i want to add as much neg camber as possible til i get my camber arms, i am also getting the guard lip rolled.
There's downsides to too much neg camber - are you happy to live with them?
IMO basing alignment settings on looks or to address rubbing is sacrilege, but each to his own. I prefer to go fast than look pretty (also, i'm never going to look pretty so its not like i have a lot of choice)
Mike, i was thinking the same thing.
I have standard wheels in case of defect but i would like to avoid defect, its only a weekend car anyway.
I'm hoping to find a good balance between the correct camber for performance and also for looks. I want my car to be a good balance between form and function.
Thanks for all the help and ideas/suggestions
20mm is quite alot! you'll need majorly stretched tyres, prob more a 35 & prob over 4 or 5 degrees camber, both of these are illegal over here, or guard work or wheels that fit
One last thing, how do i adjust tge standard camber at the rear? Sorry if its aleeady been covered
There are eccentric bolts as the inner ends of the upper arms at the rear. But they only give a smidgin of adjustment. Not going to really get you anything. And as I said, generally when you lower a Skyline you get too much neg camber at the rear, and you want to dial it out. If you carry a lot of neg camber then you get ridiculous tyre wear, very poor straight line traction (both accel and braking) and unless you are actually really hooking into corners and loading the outside type, poor lateral traction as well. If you do and have all that just to fit excessively wide wheels and tyres, then you need a straight jacket.
I'm going to roll the lip, keep the stretched tyres and add some camber, hoping I'm not going to need more than about 3 degrees of camber. If it ends up affecting performance too and tyre wear too much I'll get different rims down the track. Thanks for the input and feedback etc
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
