Custom 3.0 ltr Supercharged R31 Silhouette Skyline, Excellent condition, was used as a daily. Alot of money has been put into this car and it is worth every cent. This is a list of what I can think of from the top of my head that has been done so far:
-Has only done 152,000km
- CAI
- Limited slip Diff
- Bucket Seat
- Supercharged
- HKS Head
-Cams
- BNM Shifter Auto
- Extractors
-Straight 2.5' pipe from cat, sound mean as.
- Intercooler
- Boost Gauges
- Push button Start
- Power Windows
-Will also throw in RB25/6 + RB30 heads, cams, manifolds..
Immaculate Interior & Custom Paint. The interior is mint as for a car this age, all the electrics and lights still work on the inside
- Brand new 6 months rego + RWC done on 10/08/12 but will need to get your own unless you can make me a deal.
Note: The car has not been drifted
Give me a txt or drop me an offer if interested on 0433919956
SERIOUS BUYERS ONLY NO TIME WASTERS
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
