Well i think i have ratted my power steering doing .. err humm silly things :)
The power steering now has a slight whine to it? and when the car is stationery the steering is extremely hard to turn (ie. power steering does not actually engage until i start accelerating).
I got a wheel alignment done recently and the guy told me that my power steering fluid was a bit low, and some bubbles were in it. Possibly indicating the pump has gone..
Anyone else had this prob? If so was it the pump, and how much/where do i get one of these from??
https://www.sau.com.au/forums/topic/4087-power-steering-prob/
Why drain the system? I have had this problem, the fluid gets low and foams up with millions of microscopic air bubbles that get pumped around the system. The hydraulic fluid becomes mostly air and the power steering stops working, and the pump kicking up an ungodly whine when you turn the steering wheel off centre.
Just top up the fluid to the full mark. Now this is not ging to fix the problem immediatley because the foam is still being pumped around the system. But gradually over a couple of days the system will bleed itself and the noise will go away.
Top up the fluid again, and you will be back in buisiness.
https://www.sau.com.au/forums/topic/4087-power-steering-prob/#findComment-67283
ok i have looked underneath the car and spotted a leak. so I guess the possibility of air in the lines could be out, and im assuming i have a hole somewhere in the lines, or the pump may have a broken seal??
yeah i have topped up the fluid warpspeed, but i think the air in the lines is not my prob now.
my next q. is where do i get some genuine power steering specialists to check out/fix prob in perth??
https://www.sau.com.au/forums/topic/4087-power-steering-prob/#findComment-67567
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
