Well i think i have ratted my power steering doing .. err humm silly things :)
The power steering now has a slight whine to it? and when the car is stationery the steering is extremely hard to turn (ie. power steering does not actually engage until i start accelerating).
I got a wheel alignment done recently and the guy told me that my power steering fluid was a bit low, and some bubbles were in it. Possibly indicating the pump has gone..
Anyone else had this prob? If so was it the pump, and how much/where do i get one of these from??
https://www.sau.com.au/forums/topic/4087-power-steering-prob/
Why drain the system? I have had this problem, the fluid gets low and foams up with millions of microscopic air bubbles that get pumped around the system. The hydraulic fluid becomes mostly air and the power steering stops working, and the pump kicking up an ungodly whine when you turn the steering wheel off centre.
Just top up the fluid to the full mark. Now this is not ging to fix the problem immediatley because the foam is still being pumped around the system. But gradually over a couple of days the system will bleed itself and the noise will go away.
Top up the fluid again, and you will be back in buisiness.
https://www.sau.com.au/forums/topic/4087-power-steering-prob/#findComment-67283
ok i have looked underneath the car and spotted a leak. so I guess the possibility of air in the lines could be out, and im assuming i have a hole somewhere in the lines, or the pump may have a broken seal??
yeah i have topped up the fluid warpspeed, but i think the air in the lines is not my prob now.
my next q. is where do i get some genuine power steering specialists to check out/fix prob in perth??
https://www.sau.com.au/forums/topic/4087-power-steering-prob/#findComment-67567
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
