Hi Guys,
Im currently looking at buying a R33 GTST. Spending around the 8K mark and there are a few out there. A couple of nice 1996 series 2's i like but 1 has 120,000 but no rwc and the other is 180,000 but with rwc. Both look pretty similar with minimal mods.
Just curious what you guys think about R33's with high klm's ?? looking at the car being my semi daily drive and odd track day car.
Any help / opinions much apprciated.
Cheers Paul
https://www.sau.com.au/forums/topic/408703-buying-a-r33-gtst/
You can usually tell from the general look and feel of the interior what the 'true' kms would be. Ripped drivers seat, worn steering wheel, front dash, shift boot, any death rattles you here when you drive it, etc...
Remember to also check underneath the car as the rails and other parts that may have had abuse don't lie.
Like Hadouken said, if its got low k's it just for show. We all know these cars are brought to be driven not to be stored like a classic, (except for 1 or 2 exceptions, but not all,) so for a car 15 years + old they cant average 7500km/year. Im 'trying' :rolleyes: to sell my 33 and it doesnt have ridiculously low kms like most. My car was a daily driver except for 1 year when I was biking to work then that year it only averaged about 10,000km. High kays scare most people, but I think my car for instance, has proven itself with its reliability and it shows with the "normal" kays its accumlated over the years.
Other things to look for is if it has been looked after with regular servicing and quality products as well as what has already been mentioned.
The other way to look at it, if they (the cars your looking at) have true low k's you would have to wonder what the (motor/trans) internals are like from all the sitting around they have done with no lubrication and minimal start up and running.
Hope this makes sense.
Edited by YEE-HAA
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
