Dear Seniors
I just got my R33 GTST and am intending to convert it from AT to MT by December.
I am also going to tune up the car to a Drift Ready state maintaining street drivability.
I have the intention to do the following in due course after my MT and Exhaust initial mod and am looking at advice on Viability and availability:
1. Handling - the standard stuff like Coil over, Tower Bars and ARB. Looking for recommendations. Plus Advice if member braces are required?
2. Handling - Looking for advice if it is advicable to remove HICAS. I am looking to change my steering to one with quick release BOSS but can give that up if HICAS is more recommended.
3. Turbo - I am thinking of a Garette GT0376 or similar (Prefer Ball Bearing so the IHI comparable might be a good alternative) Looking at 1.2bar Boost Max... Any Engine mods required or recommended? Stut bolts? Pistons and Con Rods? Actually I might lower the boost if i need to take the engine apart.
4. Intercooler - the natural thing with Turbo would be a totally trick FMIC... Please recommend...
5. Auxillary parts - Fuel Injectors, Surge Tanks, External Pumps...
6. Most important part - The Brains!!! What ECU is popular here? Where can I get competent and affordable tuners? Where is a good hub dyno that wun cost me an arm or a leg? I am familiar with most modern ECUs like MoTec, Power FC, and F Con V Pro... I am unable to touch Motec and F Con due to the large amount of wiring works, Power FC due to computer connector... So I'll probably need someone to install and tune...
Glad to receive any advice...
Cheers
https://www.sau.com.au/forums/topic/408704-noob-seeking-advice/
If you just got the car I recommend you do the manual conv and then work on the handling side of things.
IMO no point in boosting the power until you know how to drift it, otherwise you just play tag with the walls. I have a friend who has just started drifting... his starter car is an R32 with an RB20E which is perfect. Simple mods will be fine, FMIC, pod filter, new brake pads/fluid are good too and some decent suspension.
If the 33 runs electronic HICAS you can remove the steering rack and replace it with a lock bar. Some places sell collars that will lock the steering rack but you're better off replacing the whole thing with a lock bar.
Mate, if your free tomorrow night head up to the track for the drift prac that's on.
If you ask for the drift trainer named Marc the officials can point you in my direction and you can get an idea of the basics from there.
As mentioned above leave the power mods for now, make the car drive right and sto right then move onto that stuff. I would also add a fixed back seat to the list for one of your first mods, it makes a bigger difference than you would think!
Also www.driftwa.com.au
I was at the back section of the track all night and yeah pretty busy up there. We had about 15 cars just in the training area!
Usually one a month at this point mate, check the WASCC web page for the calendar or like WADrift on FB ;)
Tha mate!
I happen to also notice Barbagallo Drift Assault on 30 September and 1 October... I'll be hopping by in the arvo on 30 September but I'll have to miss 1 October as I have a class test going on that day...
Cya there if u r there mate...
  • 3 weeks later...
You want to drift - sell it, buy a 32
You are talking about spending a lot of money, those parts aren't cheap, then add in labour
If it needs to be a 33, see how much a manual costs, compare the cost to what you will be paying (gearbox, shifter, decent clutch, pedal boxes and pedals, master and slave cylinder - prob going to cost you 3k or more in parts
But a 32 is much much better for sliding than a 33, more fun and cheaper
Just my opinion anyways (havin owned both and drifted both)
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
