Saw that article on smh this morning as well. But it also mentioned the trade off is the abolition of Stamp Duty and other bs taxes.
Then again, I'll believe it when I see it, most likely they'll just keep the 2 taxes together and make us lowly citizens even more poor.
Just another massive cash grab by the federal government - like reducing the duty free cigs to 2 packets.
Last time this was contemplated they worked out it would take more money to implement and collect the money than the revenue it would raise.
Read the article, it's just the NSW Tresurer. That makes it 100% not going to happen, because when was the last time the states and Feds agreed on anything to do with gst.
They are just having a sook, australia asks a lot of money for many things.
Now if they make everything taxable from overseas then we are forced to buy locally at ass rape prices. :(
Part of the reason for the local ass rape prices is because they already have to pay tax on those same parts ;) I get your point though.
For those of you who think we get taxed too much, the UK's GST is set at 20% and they also pay 10% stamp duty, basically double what we pay.
Edited by Iron Chef
From what I have "heard", it's a bit of a hit and miss
I have "heard" of items coming from China/HK/Japan and going straight through customs. I have also "heard" of products coming from the US getting flagged for taxes most of the time.
These were all roughly the same value
^ Sounds good.
However could implement risk if you need to lodge a claim for postal insurance services. (Lost / damaged goods - etc).
I believe the value of the damaged goods are still covered with or without the total transaction cost. Sender buys a gift, say $1500, buys additional insurance, sends it as a gift, declare $0 Value on customs because gifts aren't taxable, gets damaged in transit, courier company must pay for goods damaged since the sender DID pay for the item.
I stand to be corrected but I think customs declaration value is separate from the courier insured value.
Would be interesting to get a definitive answer on this!
Customs aren't dumb - just understaffed!
** Remember:- Any SAUer who's going for a short trip to Japan will be your bestest friend
**And - and - and:- If you're the SAUer going for a holiday to Japan, you risk getting pinged for XS (overweight) baggage on your return trip to Oz
Hehe...
Hehe...
Go Japan using Jetstar economy and for $70 you can upgrade luggage to 40kg but no 1 bag can be more than 32kg.
Business and its a 30kg bag and 20kg carry on. Post most of clothes back via Japan sea post and fill up on parts...but...... you run a real risk of getting smashed by customs for non duty free items.
As Terry said customs are understaffed but not stupid. Takes them as long as you to look up true value of a part.
Personally I don't think this will get through for quite awhile as while it will possibly help the local retailer, the business importer will be hurt on the flip side..bit of catch 22.
Maybe the smart move by any Australian government would be to lower the import duty and customs fees but would the business pass that discount on ?????
Bit more info here http://www.smartcomp...tm_medium=email
some wouldn't, but most would. it's not like retailers are rolling in cash at the moment, so any chance to be more competitive compared to online would be beneficial.
Quoted response from DHL:
For all products that come into Australia even if they are of no commercial value the supplier will still need to have a value for customs purpose only.
Australian customs will hold all items that arrive with a nil value on the invoice.
We will cover under insurance if the shipper selects this on the AWB but will need to put the insured value.
Anything under $1000 will go through an informal entry and no duties and taxes will apply.
So to my understanding, a value must be declared to Customs for them to clear items as all items would have a value of some sort. As for insurance for the goods being shipped, another value may be declared separately to the courier company.
Send a gift of a 24 carat diamond ring, pay for extra insurance, declare $20 value to customs, win maybe?
We're one of the lowest taxed nations in the world.
Stop complaining.
Also, this is far from a tax grab. It's slated to cost more to administer than revenue it generates and for that reason it won't happen.
    • Yeah, they look good. I should try to fit them on mine. But being a GTSt, the guard shape probably doesn't suit properly.
    • Nah, it's not a simple voltage divider. I'm not enough of an electronics guru to know how they make these circuits work. If I had a better idea of how the ECU's temperature measuring is done, I could then actually do as you want, which is turn that resistance chart into a voltage chart. But my approach has not worked. What I did was interpolate the sensor ohms values for the temperatures you listed, as you did not have any of them on a temperature ending in zero or 5. These are: °C ECU V sensor ohms (interpolated) 58 2.68 11.85 57 2.7 11.89 56 2.74 11.93 54 2.8 12.01 49 3.06 12.208 47 3.18 12.284 43 3.37 12.42 I then assumed 5V supply to the resister and calculated the voltage drop across the sensor for each of those, which is just 5 - the above voltages, and then calculated the current that must be flowing through the sensor. So you get:             Values in sensor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current 58 2.68 11.85     5 2.32 0.195781 57 2.7 11.89     5 2.3 0.19344 56 2.74 11.93     5 2.26 0.189438 54 2.8 12.01     5 2.2 0.183181 49 3.06 12.208     5 1.94 0.158912 47 3.18 12.284     5 1.82 0.14816 43 3.37 12.42     5 1.63 0.13124 And then use that current and the ECU's sensed voltage (which must be the voltage drop across the in ECU resister is there is one) to calculate the resistance of that in ECU resistor. You get:             Values in sensor   Other resistor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current   Volt Drop Resistance 58 2.68 11.85     5 2.32 0.195781   2.68 13.68879 57 2.7 11.89     5 2.3 0.19344   2.7 13.95783 56 2.74 11.93     5 2.26 0.189438   2.74 14.46381 54 2.8 12.01     5 2.2 0.183181   2.8 15.28545 49 3.06 12.208     5 1.94 0.158912   3.06 19.25592 47 3.18 12.284     5 1.82 0.14816   3.18 21.46325 43 3.37 12.42     5 1.63 0.13124   3.37 25.67816 And that's where it falls apart, because the resulting resistance would need to be the same for all of those temperatures, and it is not. So clearly the physical model is not correct. Anyway, you or someone else can use that information to go forward if someone has a better physical model. I can also show you how to interpolate for temperatures between those in the resistance chart. It's not fun because you've got to either do it like I did it for every 5°C range separately, or check to see if the slope remains constant over a wide range, then you can just work up a single formula. I'm just showing how to do it for a single 5° span. For the 58°C temperature, resistance = 11.77+2*(11.97-11.77)/5 The calc is a little arse backwards because the resistance is NTC (negative temperature coefficient), so the slope is negative, but I'm lazy, so I just treated 58 as if it was 2 degrees away from 60, not 3 degrees away from 55, and so on.
    • Um.... This is not easy. I will have a fiddle with it, but make no promises. I think, given the explicit resistances vs temperature, and your ECU measured voltages, it should be possible to match them up. I will do that by assuming a 5V supply from ECU to sensor, find out how much current would have to flow to produce that voltage, then use that current as a .... nah f**k. That won't work. The supply voltage is fixed, but there's nothing to say that the ECU regulates the current too. Um... I dunno. I guess there's a voltage divider setup in the ECU. As in, there's another resistance between the ECU's sense terminal and ground. That way, as the sensor resistance changes, that's how they get a floating voltage that varies with the temperature, without having to control the current. Give me a minute or 3.
    • *that* is a question for chatgpt (or someone that understands maths....but I'd try chatty). Drop them the table and ask for the formula
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
