Stripping down my track r33, a lot of these parts are brand new.
Was close to being finished before i have decided on a different direction.
I have put everything at good prices, so don't be surprised if I don't want anything to do with lowballers
Can post a lot of things but WILL BE AT BUYERS EXPENSE!
Located in sydney
HKS 256/264 cams retaining vct
with HKS adjustable exhaust cam gear $500 very good condition
R33 RB25DETHead
Supertech valve springs
Supertech titanium retainers
Supertech valve stem seals
Supertech seats
Head machining including multi-angle valve job, oil gallery enlargement and decking, mild exhaust porting
This is all brand new, never been used, just test fitted.
$1000
RB25 Block
Good condition
Tomei oil restrictors
ARP headstuds
$250
Tomei 1.5mm headgasket $250
Apexi pod filter $20
New Z32 arm with tome plug $250
garret 3076r .63 turbo $1200
Tial 44m waste gate with screamer pipe $250
HKS cast manifold - machined flat $650
3" dump/front pipe $200
WIth new gaskets and studs
Will do the lot for $2000
Trust/Greddy 3.5inch titanium exhaust to suit r33 gtr/gtst $1000 - very good nick, very straight exhaust minimal bends
Greddy Inlet Plenum with
Q45 90mm throttle body $750
cat delete pipe $50
JJR coilpacks $100
HKS SSQ BOV $25
FUEL
Tomei 740cc injectors $600
New Sard Fuel pressure reg $100
Walbro intank pump $50
New Bosch 044 external pump with 1.5 litre surge tank $300
COOLING
Nismo intercooler $200
Alloy radiator $50
New Greddy remote coolant reservoir $100
HKS Type S oil cooler with thermostat $500
RB25 Gearbox $1000 with new nismo gearbox mount
Blitz/ORC twin plate clutch $900
Nismo braided clutch line $100
Nismo pivot ball $50
AME Tracer TM02 18x9.5 +22
Hankook RS3's 265's 85%
Hankook Z221 265's 90%
$3500 for the lot with those tyres.....if you know anything about how good these tyres are you'd know this is a good deal.
May separate
INTERIOR/ELECTRONICS
Racetech whr4009 seat/alloy side mounts $1000
RPM 3" Harness $50
OMP steering wheel with
Removable boss kit $150
Nismo leather gear knob $40
RB25 Apexi Power FC with h/c $900
Blitz DSBC $250
Braille No Weight battery $250
EXTERIOR
Carbon Headlight intake $150
Carbon F1 side mirrors $150
Aeromotions R2 carbon fibre self adjusting wing $2000
Will get pics up later on
mate probably a couple years, haven't done too many km's.
I change the plugs every 3000km's at the most, and when i do i clean and spray them with contact cleaner.
They are in very good nick
i have a build thread here which has a few pictures of random parts etc
http://www.skylinesaustralia.com/forums/topic/349246-33-gtst-streettrack-car/page__fromsearch__1
The shell will be for sale soon with all aftermarket suspension/kaaz diff and brakes also
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
