For sale; pick up only from sydneys inner west. Best contact is on 0422 579 305.
Seats are both in excellent condition.
$800 each or $1500 the pair or nearest offer. Not interested in splitting seats and rails at this point.
Genuine Vios III on genuine right hand side super low rails.
Silver back FRP version with gradation material.
Small wear mark / crease in material above the right hand side bottom harness hole. Very very minor wear at the front of the cushion.
Rail will suit S1x, R3x, A31, C33 as shown in the photo.
Genuine Ergo II on modified left hand side rails. As this is the passengers side it's nice to have the slide handle to adjust the seat below in front where every passenger instictively reachs. Bride mechanism to flick the seat forward to let someone in the back is still there, the unviersal rails were just added on the bottom.
    • Hey guys, Just thought it might be of interest to owners of the RB25 det NEO motor, that awesomeness Nitto are in the late process to produce an engine gasket kit by end of Jan 25.  I think obviously there will be an 25det kit too. cheers, Ian
    • He is around but doesn’t really do automotive stuff anymore, mainly does commercial work now
    • Shortly after I do the usual full exhaust/ fmic/fuel pump/ R33 turbo and still get flogged at the lights by i30Ns
    • Is Chris from Craved Coatings still around? He is an ex SAU guy and did great powder coating (back in the day at least)
    • Bumping this thread yet again, has anyone ever tried putting yet another vacuum regulating valve on the hose that goes between the turbo inlet? Something local owners have mentioned is the Radium breather pipes de-restrict the valve cover but it actually produces an undesirable outcome in practice, way too much air is sucked out of the crankcase and a ton of oil comes with it as well. As far as I can tell the PCV diaphragm in these modern euro wet sump performance engines is active during boost as well, there's just a check valve to block boost from entering the valve cover and crankcase as there's no inherent check valve function in these diaphragm-type valves. Hopefully I'll be able to try some of this out soon. The Volvo XC90 4.4 V8 has a nice external version of these things.
