  • Replies 175
Now that was a good deca!!
Thanks to:
Import Monster - It's great to have you onboard and even better to see you out there driving!!
Bec - So many years you keep doing the things that no one wants to do and more to the point, what no one knows you do! THANKS! :worship:
Wayne - Every time you come up, you're the first there and the first person rounding up volunteers to run the day and then volunteer yourself from the first car to the last. GREAT
EFFORT!
The Volunteers - My favourite people of all.
From the drivers who come up and do this job when their car is broken, about to be sold or have sold, and to the people that come up for the weekend and do this job without being asked or simply just doing it because there is not enough people to do the job, a huge THANK YOU.
Every driver should go out of their way to do something special for these people!! :D :D :D
Ryan - more time out of your spare time to help make this event happen... good job.
Mike - your number 26 next deca. Little F*%$#@^! (good job mate :ninja: )
To everyone else .... Bring on next DECA!
:laugh:
hahaha awesome!
And see - Grant has evidence of said geese/ducks/whateverthefarktheywereinmyway
Looks shopped to me.
It is time to return to DECA! Bring on Deca-mber.
Thanks to the organisers, volunteers & sponsors for putting on an awesome Deca! Also thanks to those who took some awesome video footage and photos!
I didn't really get a chance to socialise much on the day, I was feeling a bit out of it - probably due to the fact I was running on less then 2hours sleep haha but I look forward to seeing you all up there for the next one :)
The car held up fairly well except for the fact I killed another fuel pump, still made it back to Melbourne before it really started playing up, luckily..
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
