Hey guys,
So Dad is looking at fixing hail damage on the 34gtt, and I figure it's about time for a respray and some new wheels as well.
Seeing as these extras are coming out of my pocket, I'd like to do it once and do it right, so I figure I should gain all the advice possible.
1. Roughly how much can I expect to be paying for a basic (not bare shell) respray? I've heard around the 2-4G mark for same colour jobs? Would it be a lot more $$$ to turn the standard black respray into a very dark midnight purple-pearl type job? (looks black until the sun hits it, then appears a very dark purple)
2. So far I'm thinking of getting Varrstoen 2.2.1 (te37 style) rims, but I'm thinking of going fairly aggressive in fitment. I want to roll and flare the guards out, but not sure how much to flare them? Ideally the fitment I want to run is 18x9.5 +22 front, 18x10.5 +22 rear. Would this be a +20mm flare in order to eliminate any chance of scrubbing? I don't want to run overly ridiculous tyre stretch either, thinking of 255's on the rear and 235's front. The other option would be to run 18x9.5 +12 at the rear.
3. Where would you recommend taking the car to get the guard and paintwork done?
https://www.sau.com.au/forums/topic/408852-r34-gt-t-overhaul/
I doubt it will cost much more then, do you have an insurance quote already?
If so go see the panel beater and ask the question
If you don't have an insurance quote yet go get one
I would go see naz at KMF (he only does quotes on Saturday) or the guys at prestige who did sins car
Get the insurance side of it done after that's done ask for a cash price on the colour change
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
