I have read a lot of things about the Splitfire coilpacks and they seem to be the go for replacement as mine are starting to die under boost. But i heard people only buying the splitfires because the OEM ones were too expensive.
But it seems the OEM ones are 90$ each which ends up cheaper than the splitfires, would you guys recommend them over the splitfires ? Say for higher than stock power running 20psi boost, or is the splitfires better for non stock skyline.
Also i read that these clamps were good but i cannot remember where i read it from, worth the 50$ for 10 ?
http://www.autopartswholesalers.com.au/products/hose-clamps/norma/norma-constant-tension-hose-clamps/normaclamp-torro-ct-constant-tension-worm-drive-hose-clamps-packs-of-10-
https://www.sau.com.au/forums/topic/408860-coilpack-and-clamp-choice/
I got some brand new OEM coils for about $500 a set and am running them at 20psi soon to go to 25 psi. Someone said there are some fake OEM around but mine seem fine (bought them off an Aussie on Ebay).
Have you verified theres a problem with the coilpacks? If its an assumption, start with plugs first because there a lot cheaper and you already have good coilpacks. What gap are u running? More boost means smaller gap.
These are from Kudos so i trust they wont stock fake ones!
I change my plugs every 5000kms and use copper plugs gapped at 0.8mm. Quiete often when i gun it and it revs in the highs like 4500+ the car will just die for a second.
And my coilpacks seem original with my 100k+ kms and they have been siliconed in the past.
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
