Hi guys, just bought a set of 275/35R19 tyres and had them fitted to my rims 19x10 + 20. I am getting some fairly significant rub on full lock and at any time the car bounces while driving (oh yeah aso have adjustable coilovers). Would you guys say it's because of the 35 profile on the tyres or the +20 offset of the rims? Do you think if I went to a lower profile tyre (30) it would alleviate this problem?
What tyre sizes (and rim size with offset) are you guys running on your GTRs and do you get any rub? Cheers
ps. I am aware there is a similar thread already running, however I thought this would be easier for the 34 GTR owners rather than sifting through pages of forums, with this thread also specifically being about tyre rubbing :)
Edited by Iron Mike
  • Replies 41
Posted Images
i haven't got a gtr, the 30 profile will only help in the same way as raising the car slightly, assuming the guards are rolled already, you could try a stretched tyre, raising it up, more camber or more offset depending on where it's rubbing on full lock
This ^
Raise the car until it doesn't scrub or roll guards
Just for ur interest I've got 18x10 + 18 with ku36 265/35 all around and these tyres are chunky with no stretch
Raised the car afew millimeters and no rubbing
This is on 32 gtr, ur 34 has bigger guards
As above it will be too low rather than offset related.
I'm running 19*9.5 ET2 (265/30 tyres) & I'm now getting a lot of rubbing on the fronts since lowering my car more
Really need a roll
Dunno if you guys have seen it, but i used the miata tyre calculater to check the tyre sizes. I had stretched 245/45-18 on my last rims, which were 18x9.5 + 12, and with the new tyres, the diameter/radius of the whole wheel is almost identical, which leads me to believe that it probably isn't the profile of the new tyres causing the rubbing and may just be the wider tyres or the higher offset with the current rims (+20 as opposed to +12 on the 18")...
Yep 19x10 with a 275/35 - what do you expect?
You can fit 18x10.5 with a 285/30, still have a little rubbing if it's too low - this is all the same stuff we went over in your other threads anyway.
this. You asked if it would scrub, we said yes, you didnt listen
What tyre/offset combos in 19" do you think would minimise this problem or is it inevitable? I remember guys with GTRs running 19s with no rub, just cant remember what tyres and offset :/
I think you're thinking of the wrong member. I don't remember asking this question anywhere!
First of all a 275/35 is a dumb size, there is no other way to put it. It's so wrong it's not funny...
Anyway you need a 275/30 - then you get an extra ~1cm to play with. It's MUCH closer to stock diameter which will stop your speedo being "too" far out. With a 35 profile tyre it'd be so far out it'd be ridiculous.
Either way you cannot have both (10" rim and a 275/35) if you want it remotely close to lowered.
You want lower you have to go with a 275/30.
OR
Going back to a 265/30 on a 9.5 and it's over 1cm and almost the same diameter as factory - which is what most people do
Only reason I didn't go for the 30 profile was that many people were saying it's really bad for the rim if you hit a pot hole, but I dont know seriously how much difference going up to a 35 profile would make anyway. Secondly the diameter of the wheels im running now are almost identical (only 2 mm larger) to the diameter I had when I was on 245 18s with a 45 profile...
:huh:
Regardless of 30/35 - you hit a pothole - shit is gonna get farked up!
You'll end up rubbing on the inner guard would be my guess.
As i said a 18x10.5 & 285/30 combo will rub with a moderately lowered 34GTR on the inner guards. Going 19s isn't going to make it any less likely even going a 275 which is only marginally smaller
Whether or not it effects rubbing but rolling circumference of the tyre is too big for your car. Buy the correct size tyres FFS.
Hey Anthony, can you please send me pictures of your wheels and where it rubs. I'm looking at getting the same wheels but with +12 offset and dont know if its only going to compound my problem. What made you go for the 35 profile also?
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
