Ive got a gcg highflow ball bearing turbo on an rb20 I have 3 inch full exhaust, fmic, its running 10psi. It just starts making boost around 4000rpm and reaches full boost around 4500rpm. Was just wondering if this is normal for this setup or is there something I can do to change this
https://www.sau.com.au/forums/topic/408874-gcg-highflow-turbo-on-32-laggy/
Check that you have enough preload on the actuator.
How could I check the preload on the actuator?
And its a standard ecu
Move the push rod on the flapper or remove it and make sure there is sufficient effort to get it back on.
Also, is it a bush bearing highflow Or ball bearing?
if it has an adjustable turnbuckle on the waste gate adjust it in ( smaller in length) by half a turn and go for a test drive and repeat
could also be bad cam gear timing ifs its been touched recently
Edited by Dan_J
its a highflow rb25 turbo so bigger twice over than a standard rb20 turbo, I'd expect it to come on around then
winding up the actuator with stock ecu is a very bad idea as it will raise boost once
the correct pre load is reached
if you do it drive very carefully and watch your boost gauge
as soon as it starts to run more boost wind it off half a turn till you tune it
Edited by 1400r
i used to make 10psi at 4k with a s2 r33 front/ 0p6 rear trubo on the rb20 with the stock smic
for the gears, just confirm so its not a tooth or 2 off, the dot on the gears should match up with the cam gear cover backing markings
double check cas timing
stuffed cat?
if its just turbo lag you can get adjustable cams , retard exhaust and advance intake
shorten cooler piping
tune
A photo of the turbine wheel would be good. I've had few of their high flowed units came in for service, they were carried out using factory bearing housing, with cropped TA34 turbine wheels. if that is what you've got in your Rb20det high flowed turbo then yes it will be laggy, how ever it should be ok top end wise.
turbocharger configuration for Rb20det needs to be treated as a Sr20det, Turbine wheel to any thing above the size of a 2530 will feel laggy.
^^ im sure you would lol. The most fun to drive rb20 i've ever been in had a standard turbo , it was rather stripped of anything that wasn't necessary . People place too much emphasis on bigger turbos and expensive things to make their car faster , without doing the easy free stuff first! . I remember an interview with the late peter Brock and listening to him explain how he took like 30kg out of his Torana just by shaving all the excess off every bolt on his car ... My point being , that turbo has probably made your car slower over all , what hyper gear said about rb20 being similar to Sr is somewhat true , for street duties i don't think you would find much better than a 2871r or high flowed std 20 turbo .
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
