get a ball bearing 2871r core into your rb20 or rb25 housings, for response use the rb20 housings, for more mid to top use the rb25 housing
also, use a good boost controller to bring it on early and keep it on as long as possible, if possible get some ethanol too and wind up the timing with a tune and 20psi of boost..
Ahh yep , well , tune , cam gears etc . It will never make full boost under 4k with that turbo (nor will most after market turbos)
currently making 15psi at 3.7k on a hyper SS1 still need cam gear adjust, advance cas timming and a tune
That's a hypergear , not gcg :P . I will change my statement , just for you my good friend :) , i have never seen a gcg high flowed turbo make full boost under 4k :) . That's pretty good old mate , even my old 2530 didn't make that by then!
I presume you are talking about an RB20 - if you look at my chart above you will see it makes full boost by 3500 rev/min on my old RB25
hey guys had a quick look at some stuff today. the actuator rod wasnt adjustable but i removed it and put it back on it wasnt realy hard but it had no freeplay. i got some numbers off the turbo plate aswell.
on the turbo : ae147
xtrgtsts1
on the actuator its probs not a part number though: nissan asn79-
i also noticed that i have a leaking fuel injector that i will have to fix.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
