Hey all
Have a gt3076 .63, 4 bolt rear housing, external waste gate
Comes with oil/water lines
Has only done a couple thousand km's. great condition
Has some scratches on the intake side due to intake pipe rubbing, nothing major.
$1000
HKS Cast Manifold, low mount, with external waste gate provision
I had the surface machined flat when i got it, has been test fitted since but never run since.
Includes genuine nissan head to manifold and manifold to turbo gaskets, only been fitted never run
$650
Tial 44mm waste gate with screamer pipe
$250
3" dump/front pipe to suit 4 bolt rear housing, with 02 sensor
with metal gasket
$200
Will do the lot for $2000, also have intercooler pipes to suit this setup
Will make 300rwk no worries with awesome response
Located in sydney
also have a greddy inlet manifold, intercooler pipes, and tomei 740cc injectors that go with this kit.
And also have a power fc and z32 afm.
Will do the lot for $4500, or $3500 without the power fc
That's basically a bolt on 300rwk or more depending on fuel.
Okay cool well I'm just after the turbo kit (mani, turbo, waste gate and dump) I'll contact you next week when I get paid and we can work out something. You got a number mate? Or should I just PM you on here?
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
    • You are also getting pressure dips on gear shifts. They're just not dipping as far, but they're dipping quite below the amount of oil pressure you should be seeing, for how much RPM drops.   It quite little could be the oil pressure relief valve is starting to stick open a little/is slow to close.
    • Can you log battery voltage, and TPS, and put all four of those into a single image (even as split graphs)?   The oil pressure drops aren't following RPM as such. I'm intrigued if you may have a ground loop between different sensors. With the engine not running, log your sensors and for example cycle the throttle pedal. See if any sensor values flutter or move about. This won't be a perfect test either as the ECU won't be cycling all of its actuators like it would be while running. What EMTRON do you have? Do you have a link to the wiring guide for that ECU?
    • What logic functions do you feel are missing from the Haltech that others have? Is there a limit to how much logic you can string together? By limit, I mean it's like only a single level or two levels of Boolean logic. Realistically, AND, OR, and NOT, is really the only logic you need and realistically, you can also do away with another logic gate of the three above . With those three you can build the full functionality of any Boolean logic you want.
    • Well that rules out the relocation theory, however with no load, you're still getting 1.5bar of oil pressure. Can you present that data in a scatter graph over longer period? Would really highly the anomalies. Wish Haltech could do that.
