My R34 GTT shows moderately high oil temperatures (100+) and bit of steam coming out of the radiator. Water temperature shows normal though. Car cools down in few minutes after I stop but Im not dirving it anymore until I fix the issue.
So Im upgrading the entire cooling system :rolleyes: (radiator, pipes, thermostat and water pump). Im looking at a 40mm aluminum radiator from ebay. Replacing the radiator is a kids job.
But how hard is it to get to the thermostat and water pump? I could find topics on RB25DET but not much info on the Neo engines. Any leads on this would be much appreciated.
Thanks guys
Flush the system before changing Anything with heater on !! So the heater core can be flushed as well
Thanks guys
Use top coolant , never mix with tap water or another brand ,
Good time to do hoses as well as mentioned
Belts as well
alloy Radiators dont always fit perfect even name brand ones !! if your mounts have sagged on tranny, engine or radiator the shround might hit
Or rub on frame rail
If you havent done water pump and timing belt do it now to save the hassle if needed and $$
replace the radiator cap to 1.3 bar cap , to raise boil temp
Buy redline waterwetter or motul cool and dump in before totally full up , it makes a dramatic difference
Use aviation gasket sealer and factory parts or nismo items , the aviation gasket seals it the first time not tenth time , permatex brand , messy so dont get it on the car or your clothes
the thermo is easy just put it in right side up lol
expect rusty bolts and muck to come out of flush even on a well kept car
Drain air , burp the bottom hose a few times before starting to get air out , , pull overflow out and use non kerosene based cleaner and a baby bottle brush inside to clean it replace hose to it while out as well and prefill to max
it should suck some in the first few hot cold cycles then stablize at full , make sure you have heater on hot !! Or airpockets will fill head and heater core and destroy the head if bad enough !!
buy all new hose clamps as well , makes life easy and on silione hoses the old ones cut in
Check the coolant daily cold For a week then if its all good every fill up of fuel is a good time for a glance at it ?
Don't do this. It might stop the water from boiling but you don't want to get up to standard boiling temperature anyway, you're exponentially increasing the cavitation of your cooling galleries. If your water is getting close to standard boiling temperature then stop driving, don't just raise the boiling point.
agreed.
+ unless you plan on changing ALL hoses on the motor then puttin a 1.3 bar cap on is quite likely going to start popping these too (iv had so many friends do this). Rememberyou have a car that would be around 15 yrs old now. Those hoses are in good nic anymoe...
Thanks guys. I've ordered a 52mm aluminium radiator. It seems to have the right holes for mounting the shroud. Hopefully it will fit.
Apparently the water pump (N1) and thermo was done few months ago by the previous owner. So I'll probably skip those.
I reckon the only reason why my radiator failed was becasue I had low coolant concentration and more water in the system. I was literally flogging it when it failed lol. To add to this, my boost sensor was not plugged in then and the car was running lean. So it probably raised the temperature quickly.
Hopefully the car will back on the road on friday :whistling:
Thats not how the cooling system works mate
If you run the .9 factory one you run the risk of boiling over on the track days or super hot days in traffic , it was never designed for australian conditions !!! Which are way more severe then most places on the planet
You can run the factory one but it should be replaced with new radiator anyway ( the radiator comes with a new 1.1 bar cap but horrible quality imo
Most new caps run 1.1 to 1.5 including nismo caps , my nismo cap 1.3 bar and 52mm alloy radiator with n1 style pump and nismo thermostat with redline waterwetter and red heavy load organic coolant runs cool as hell on smoking hot days and the thing actually shows on laptop on the dyno the nismo stat opens sooner to let coolant cycle sooner , 3 blocks and the temp is up
Grounding the coolant also helps oxidation from occuring , most failures are rust or oxidization issues caused by mixing coolant brands, tap water ( hard water) a gauge mount in the hose or a small gauge wire to ground extends the quality long term sounds weird but its documented to help ?
Did the 52mm Radiator fit well mate?
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
