2 of the Lumiled LEDs in my centre brake light are dead. Because of the way the LEDs are wired, this means that the centre brake light didn't work at all.
I've tried a few places to see if I can buy replacement LEDs, and the best I can find are tri-coloured LEDs from Jaycar. These have 4 legs - one being a common, and the other 3 being for the 3 different colours. I've cut off the blue & green legs, and soldered the LEDs to the board, and they work. The problem is that they just aren't as bright as the original ones, so I've got a dull bit in the middle of the light.
Has anyone managed to find a supplier of suitable LEDs in oz? Or does anyone have a broken centre brake light they don't want?
https://www.sau.com.au/forums/topic/408902-leds-for-centre-brake-light/
I replaced the centre rear break light on my 33 a few months back... I went out to autobahn and got some SMD LED lights and replaced the old panel with them. I found that because the plastic housing is red, buying white SMDs gave me the required brightness. SMDs are basically super bright LEDs... give them a try if your up for it... worked of me xD
Not necessarily. SMD stands for Surface Mount Device and makes no reference to the performance characteristics of the LED in question.
Therefore, be sure to pick out LEDs which have the appropriate brightness, measured typically in candela (cd) in luminance terms (intensity) or otherwise lumens, in illuminance terms (flux). The difference between the two measurements is the luminance is the perceived light from the LED whereas the illuminance is the perceived incident light on the surface of the object that the LED is shining on. That's why you typically find luminance measurements for LEDs intended as indicators as opposed to illuminance measurements for LEDs intended for light globes and torches.
Obviously, the higher the number, the brighter the LED.
You'll probably find that port3s' recommendation might be the more cost effective way to go. Not having seen these tail lights myself, I don't know what the direct replacement is for these things so I can't make any recommendations but if I were to start looking for bits, I'd look to the auto parts guys first too. Failing that, I usually look at guys like RS Components and Element14 as they generally have what I'm looking for, though at a premium.
Edited by The Max
The LEDs I got from Jaycar are SMD, just not as bright as the originals. I'll try Autobahn. Did you buy a complete light panel from them? Note that my lens is clear, not red, and the existing LEDs are definately red - this is the centre light (the one on the rear parcel shelf), not the combo taillights or a spoiler mounted light. I don't have a spoiler (unfortunatly).
The other suggestion I forgot to make as well is that if you are unsure what the luminance characteristics are of the existing LEDs, you would be best advised to replace them all so that you don't wind up with any hot/dim spots in your LED array when they're active. Do you have the Jaycar catalogue number of the dimmer LEDs you bought?
Edited by The Max
Looking at the specs, they're 200mcd, which is not all that bright. Also, they're tri-colour which means you've paid for two other colours which you don't need in your brakelight since it's a clear lens. Had it been a red lens, you could then use all three colours to achieve white.
Nevertheless, you'll need more than 200mcd luminance, it seems. The perceived brightness is logarithmic so for double the brightness, you'll need around 450mcd, quadruple brightness is around 670mcd and so on.
Listen to Tony.. what is says is correct.. there should be plenty of high intensity red LEDs available, you just might need to look further than Jaycar.
I also suggest you replace all of them while you am there, even if you can get the same spec LEDs, the older LEDs will have lost some of their intensity, and you could end up with a 'hot spot'.
Does the center brake light really use SMD LEDs? I expected they would be normal 5mm LEDs.
Im stealing that part of the quote :P
Definitely surface mount - there are 6 LEDs arranged as 3 pairs (each pair in parallel), then each pair in series with the other 2. There is also a diode (for rev polarity protection probably, not sure why though as the LEDs will do that) and a pair of current limiting resistors. I've got the old ones here somewhere, but physically they are the same size & shape as the Jaycar tri-colours, but only 2 legs (obviously - 1 colour).
It's in & working now, I'll keep my eye out for more suitable LEDs & change them if I find some.
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
