Im wondering if anyone can help
My mate decided to wash his engine bay the other day and when he turned the car off the car just died half way through the turbo timer countdown. He tried to start it and it wouldnt start and when it eventually did it idled very low like around 400-500 rpm and was constantly dieing. We turned up the idle screw on the throttle body to get it to run at around 750-800rpm.
Took it for a drive, everything seemed fine but when we turned the ignition off it did the same thing, was really hard to start.
I turned the idle up even more and it seemed to only have trouble starting when it was left for a while
Its obviously got water in somewhere so we pulled the coil pack cover off and all the coil packs were bone dry, undid every electrical plug that we could see and blew it out with the compressor, cleaned panel filter just incase any water got in there.
Still the problem is there. Any suggestions?
Starting problems are always going to be fuel or spark related. Given the circumstances, it's pretty safe to assume it's going to be spark. So you shouldn't have to adjust the IAC or anything else. Start by checking your spark, see if it's good or weak or just not there at all. My money is on the crank angle sensor.
Its probly pure coincidence that its happened just after you washed the engine bay. I wash mine all the time, have done all of my cars and never once had a problem. But you should always be sensible where you point the hose.
Im with above. Either that or your fuel pump has died/dying.
Nissans and tap water is a bad idea , nissan connections fail really easy once corrosion sets in
Could be ten things , most likely coil pack harness
Or injector harness, cas or tps , wouldnt be fuel pump unless it was a fluke
could be afm as well
Sometimes just letting it sit fixes it once it dry again ?
my moms 120y engine block had a inch of grease on it but never faulted her, i drove it once and washed the grease off it never ran right again lol like a blanket of sludge haha
you really have to use care or its trouble chasing corrosion
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
