hay guys
i just bought a r34 last sat its pretty much stock standed execpt for a hks bov.
im looking to buy a front mount intercooler kit to fit my r34 gtt with out much mods.
ive seen some on ebay for abt 350 ? is it a good idea to buy it from their ?
what are some things i should know or look out for be for buying one.
https://www.sau.com.au/forums/topic/408925-intercooler-kits/
Check Plazaman's cooler kits. they cost bit more but they are very good at heat exchange. Had one on 24psi and the cool side end tank remain cold through out the dyno tune. Wither some of the cheap return flows coolers turned burning hot after couple of runs.
Get TBE 1st before FMIC, & as for FMIC I would just get the just jap black return flow one as it bolts using the stock pipe locations without having to cut holes & its stealthy...
But if you are not going to run more boost than stock, I wouldn't bother with a FMIC at this stage.
Go to a truck wreckers, buy one of the 900 x 600 coolers from a scania.
Take it to a workshop and get it cut down to 3 x 300 x 600 coolers.
Get some end tanks made up for them with no flow testing what so ever.
Get soem custom piping made up from mild steel cause it's just as good.
Polish the end tanks with Autosol for hektik shine.
Hack up your front bar to fit the cooler.
Sell the other 2 coolers left from the cut down truck core for profit.
Edit. Shit sorry. For some reason I woke up thinking it was 1998 today.
Edited by TTT
truck coolers actually flow too much, being the fact that the air travels too fast throught the core to cool it effectively, ebay coolers are fantastic for the price have use them on customers and my own cars from 300-800hp with back to back dyno full power tuining runs with consistant IAT's,
regards
Drews Performance
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
