LANDSCRIBBLE Posted September 9, 2012 Share Posted September 9, 2012 There is just an elbow, tube and k&n pod infront of the thing, no fittings for the BOV or rockers. The turbo outlet and cooler pipes are pretty clean. Has anyone came across this before? Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/ Share on other sites More sharing options...
Dale FZ1 Posted September 9, 2012 Share Posted September 9, 2012 Are there traces of it in the trunking from K&N - compressor? Give the filter a clean, don't apply excessive amounts of the filter oil. Then give it another run after wiping out the stuff shown on the comp inlet and see what happens. Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525188 Share on other sites More sharing options...
Moodles2 Posted September 10, 2012 Share Posted September 10, 2012 Might need to clean out the cooler piping and intercooler, maybe install a oil catchcan to see if you've got excess blowby etc. Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525544 Share on other sites More sharing options...
Dale FZ1 Posted September 10, 2012 Share Posted September 10, 2012 no fittings for the BOV or rockers. The turbo outlet and cooler pipes are pretty clean. No blowby is going into the comp inlet according to the original post. Limited source of origin. Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525576 Share on other sites More sharing options...
GTScotT Posted September 10, 2012 Share Posted September 10, 2012 has it ever had breather hoses connected? How dirty is the K&N? as said above they are oil based and you wouldnt want to over lubricate them. If its dirty it could be getting passed the paper element. is there much build up in the cooler pipes? That will give you a better indication of where its coming from. Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525591 Share on other sites More sharing options...
Dose Pipe Sutututu Posted September 10, 2012 Share Posted September 10, 2012 looks like the K&N had it's mum lubricated lol... give it a wash and use very minimal amounts of the K&N lubricant, or better yet, get a dry type air filter, I'm not a big fan of oil based air filters. Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525606 Share on other sites More sharing options...
LANDSCRIBBLE Posted September 10, 2012 Author Share Posted September 10, 2012 I was thinking if excess blow-by could be the cause. Compression test prior to discovering this was between 130-117psi across all 6. The BOV doesnt fully open until it see's full boost (20psi), so it flutters like its blocked off most of the time. I bought the filter brand new only 3 months or so ago, havent cleaned it yet. Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525628 Share on other sites More sharing options...
LANDSCRIBBLE Posted September 10, 2012 Author Share Posted September 10, 2012 Since i put this turbo on earlier this year it was just running stock turbo with pcv connected. Had recently installed a catch can, noticed there was some oil thats been sprayed around the the catch can hose joins and breather. The clamps werent loose either, the thing felt empty. Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525654 Share on other sites More sharing options...
AngryRB Posted September 10, 2012 Share Posted September 10, 2012 are there any 2years old's running around with a black crayon Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525657 Share on other sites More sharing options...
Dose Pipe Sutututu Posted September 10, 2012 Share Posted September 10, 2012 Since i put this turbo on earlier this year it was just running stock turbo with pcv connected. Had recently installed a catch can, noticed there was some oil thats been sprayed around the the catch can hose joins and breather. The clamps werent loose either, the thing felt empty. put some steel mesh/wool into it, might collect more oil vapour Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525658 Share on other sites More sharing options...
GTScotT Posted September 10, 2012 Share Posted September 10, 2012 but you said there are no breather hoses or bov pipes hooked up? So it cant be from there. Unless were all confused now? Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525667 Share on other sites More sharing options...
Hanaldo Posted September 10, 2012 Share Posted September 10, 2012 Unless were all confused now? This is me Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525714 Share on other sites More sharing options...
LANDSCRIBBLE Posted September 10, 2012 Author Share Posted September 10, 2012 but you said there are no breather hoses or bov pipes hooked up? So it cant be from there. Unless were all confused now? haha sorry, correct. My knowledge of these things is still poor. Can blow-by come back out through the intake plenum, throttle body, intercooler and then turbo? Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525777 Share on other sites More sharing options...
jjman Posted September 10, 2012 Share Posted September 10, 2012 it has to be the K&N if there is no other input into the intake pipe. unless BOV flutter can force air back past the compressor wheel? couldnt imagine it being possible n to the level of oil that is there. But i dont have flutter so not surewhat it can do... Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525809 Share on other sites More sharing options...
LANDSCRIBBLE Posted September 10, 2012 Author Share Posted September 10, 2012 it has to be the K&N if there is no other input into the intake pipe. unless BOV flutter can force air back past the compressor wheel? couldnt imagine it being possible n to the level of oil that is there. But i dont have flutter so not surewhat it can do... These are my thoughts aswell. Ive got a cheapo dry filter i might use that again Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525837 Share on other sites More sharing options...
Dose Pipe Sutututu Posted September 10, 2012 Share Posted September 10, 2012 let's clear the air, take a photo of your setup. Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525844 Share on other sites More sharing options...
GTSBoy Posted September 10, 2012 Share Posted September 10, 2012 The definition of "flutter", being reversion, means intake air being forced back out through the compressor wheel against its rotation. Hence the noise. If the pipework between the turbo and the engine is oily (and there may be some from the turbo itself) then oil could go back out through the compressor. But that stuff looks like it has only been flowing in one direction....so I'd have to guess it is filter oil, or perhaps a load of water got at the filter at some stage, washed crap out of / through the filter and carried it to the turbo. Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525863 Share on other sites More sharing options...
jjman Posted September 10, 2012 Share Posted September 10, 2012 The definition of "flutter", being reversion, means intake air being forced back out through the compressor wheel against its rotation. Hence the noise. If the pipework between the turbo and the engine is oily (and there may be some from the turbo itself) then oil could go back out through the compressor. But that stuff looks like it has only been flowing in one direction....so I'd have to guess it is filter oil, or perhaps a load of water got at the filter at some stage, washed crap out of / through the filter and carried it to the turbo. ah ok it is pusing right the way through the compressor wheel. I thought it was only a pressure wave bouncing back n forth between the throttle body and the outlet side of the compressor... And yes, agreed that it looks like it is flowing in from way upstream (filter). But to be really sure pull off the pipe from the compressor outlet. If there is heaps of oil there then turbo seals + flutter is likely. If little or no oil then can probably conclude filter oil. Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525908 Share on other sites More sharing options...
GTSBoy Posted September 10, 2012 Share Posted September 10, 2012 Yuh, once is stalls the compressor wheel speed down far enough that it doesn't have the "power" to overcome the high pressure air in the pipe, it spills back out. Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6525921 Share on other sites More sharing options...
Yeedogga Posted September 10, 2012 Share Posted September 10, 2012 Is it just me or is the oil 'vortex' pattern going the opposite way that the air would be sucking into the compressor wheel? IE: the compressor wheel is spinning clockwise (and so pulling air from the 'left' of the vanes) but the oil pattern seems to be going anti-clockwise? Or have i misunderstood basic fluid/air physics? (most likely) Link to comment https://www.sau.com.au/forums/topic/408942-black-substance-around-turbo-inlet/#findComment-6526059 Share on other sites More sharing options...
