Are there traces of it in the trunking from K&N - compressor?
Give the filter a clean, don't apply excessive amounts of the filter oil.
Then give it another run after wiping out the stuff shown on the comp inlet and see what happens.
has it ever had breather hoses connected?
How dirty is the K&N? as said above they are oil based and you wouldnt want to over lubricate them. If its dirty it could be getting passed the paper element.
is there much build up in the cooler pipes? That will give you a better indication of where its coming from.
looks like the K&N had it's mum lubricated lol... give it a wash and use very minimal amounts of the K&N lubricant, or better yet, get a dry type air filter, I'm not a big fan of oil based air filters.
I was thinking if excess blow-by could be the cause. Compression test prior to discovering this was between 130-117psi across all 6. The BOV doesnt fully open until it see's full boost (20psi), so it flutters like its blocked off most of the time. I bought the filter brand new only 3 months or so ago, havent cleaned it yet.
Since i put this turbo on earlier this year it was just running stock turbo with pcv connected. Had recently installed a catch can, noticed there was some oil thats been sprayed around the the catch can hose joins and breather. The clamps werent loose either, the thing felt empty.
put some steel mesh/wool into it, might collect more oil vapour
but you said there are no breather hoses or bov pipes hooked up? So it cant be from there.
Unless were all confused now?
haha sorry, correct. My knowledge of these things is still poor. Can blow-by come back out through the intake plenum, throttle body, intercooler and then turbo?
it has to be the K&N if there is no other input into the intake pipe.
unless BOV flutter can force air back past the compressor wheel? couldnt imagine it being possible n to the level of oil that is there. But i dont have flutter so not surewhat it can do...
These are my thoughts aswell. Ive got a cheapo dry filter i might use that again
The definition of "flutter", being reversion, means intake air being forced back out through the compressor wheel against its rotation. Hence the noise. If the pipework between the turbo and the engine is oily (and there may be some from the turbo itself) then oil could go back out through the compressor.
But that stuff looks like it has only been flowing in one direction....so I'd have to guess it is filter oil, or perhaps a load of water got at the filter at some stage, washed crap out of / through the filter and carried it to the turbo.
ah ok it is pusing right the way through the compressor wheel. I thought it was only a pressure wave bouncing back n forth between the throttle body and the outlet side of the compressor...
And yes, agreed that it looks like it is flowing in from way upstream (filter).
But to be really sure pull off the pipe from the compressor outlet. If there is heaps of oil there then turbo seals + flutter is likely. If little or no oil then can probably conclude filter oil.
Is it just me or is the oil 'vortex' pattern going the opposite way that the air would be sucking into the compressor wheel?
IE: the compressor wheel is spinning clockwise (and so pulling air from the 'left' of the vanes) but the oil pattern seems to be going anti-clockwise?
Or have i misunderstood basic fluid/air physics? (most likely)
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
