  • Replies 68
carbon fibre bonnet - 1200
18' wheels - 1500
new t04 turbo - 900
new manifold - 500
new intake plenum - 600
bosche fuel pump - 550
malpassi rising rate reg - 150
microtech LTX16 - 1300
670x300 fmic - 600
fmic piping - 150
dump pipe/front pipe - 150
external wastegate - 300
neons - 200
future mods
rb30 - 100 (paid for)
forged pistons - 1100
supercharger - 350
piping - 100
n1 oil pump - 600
n1 water pump - 150
Not going to list them man but its somewhere around the $50K mark, good chance it’s a bit more really. The cars not that powerful but it’s had just about everything in it replaced, you could call it a 2004 GTSt :D The only think I have not replaced is the steering wheel, but that’s after market anyway :)
Guest RedLineGTR
Not going to list them man but its somewhere around the $50K mark, good chance it’s a bit more really. The cars not that powerful but it’s had just about everything in it replaced, you could call it a 2004 GTSt :) The only think I have not replaced is the steering wheel, but that’s after market anyway :)
geeez crazy shit :D
only got registered today and so far it's got the following:
$225 rear strut brace
$1000 brembo's
$30 door trim
$550 front pipes
=$1805 for 1 day rego lol, expensive toys but who here would have it any other way????? :D :wassup:
Let's see in less than a year of owning my R32 it owns me:
Pirelli tyres - $800
clutch cylinder + head gasket + turbo seals + major service - $1500
Walbro fuel pump - $170
Blitz boost gauge + exhaust temp gauge - $570
HKS turbo timer - $150
A'PEXi S-AFC II - $300
momo gear knob - $150
steering wheel - $100
tints - $220
A'PEXi Power Intake - $190
A'PEXi strut brace - $160
Blitz LM Intercooler kit - $840
Focal Utopia splits - $550
JL Audio sub - $175
misc. cleaning agents - $300
SAU seat covers - $50
Quicktrak stuff- $400
services - $300
insurance - $3300
rego + ctp - $800
to come:
gear to be installed - $650 :D
headunit - $400
interior re-upholster - $300
suspension - $1500
exhaust - $1200
rims - $1500
rotors - $800
$7500.00 including purchase of car quite pitiful really
$2500.00 car R31 skyline,aussie RB30 gx model
$1500.00 RB20 DET & box
$800.00 HYBRID fmic
$1200.00 microtech LTX-12
$1500.00 fmic piping,pod,tune,exhaust,bov,bits too finish conversion
200RWHP
In modifications, my car has cost me about $2,800 :(
...thats including the suspension, intercooler, turbo, injectors, clutch, new trim blah, blah,blah....
Now that i look at the figure on the screen it doesnt look so bad, but it feels as though i have spent a whole lot more on it :confused:
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
