[Vic] Jvc El Kameleon Cd Head Unit, Top Of The Range. Can Post Australia Wide
The KD-LX30 is JVC's new high performance El Kameleon II anti-theft CD Receiver with CD Changer Control. This a very unique, top of the line head unit and people that know about stereos will know this
It features dual gold 4V pre-amp outputs, a sub-woofer output w/ crossover, and an adjustable auxiliary input. Other standard features include a 45 Watt X Four Channel amp, BBE II Sound and JVC's best HS-II tuner. Added convenience is provided with a card-type remote, Audio Cruise mode and CD Text capability.
45 W x 4 Max. Power Output
CD Text for CD Player and Changer
1-bit DAC
CD Changer modes:2 Random Play, 2 Repeat Play and 2 Intro Scan modes
CD Player Intro Scan
Direct Disc Select (1-12)
CD Player Random and Repeat Play modes
HS-II Tuner. European Switchable Tuner.
18FM+6AM Presets
SSM (for FM)
AFNS/PNC
Display: Volume Meter, , Switchable Dimmer
Card-Type Remote
Sound Control Memory
COMPU PLAY
Beep Tone Support, Rotary Encoder, Power-Off Eject, Preferred Setting Mode, Power Antenna Lead
Direct Track Access (1-12)
BBE High Definition Sound
Electronic Volume Control
Audio Cruise Mode, Bass/Treble/Balance Controls, Volume Attenuator
4 Line Level Outputs (V)
Line Out Terminals (2 pair/gold)
Preamp Fader Control
Here is youtube video on the head unit, so you can see some of the functions
The unit is in very good condition, The sound Quality will blow you away,
it is missing the remote which is cheap like about $20 to buy.
Asking $200 for the unit, No time wasters please.
This unit has a RRP of $799
Pick up is from Glenroy - Melbourne. Can post Australia wide for an extra $15.
Call or sms me if interested on 0422756270
Screen goes completely black when you turn it off for security
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
