Not sludgy at all motor is fine the turbo line is blocked
so you're saying it is blocked? seen a few cars with turbo oil starvation problems, usually blocked lines/filters if it has them, it's getting oil in the exhaust after it seizes you mean?
Yeah I mean was running fine then the rear turbos exhaust wheel blew cos of shaft play it was hitting the inside of the turbo housing so I changed the turbo now it's make only 7 psi instea of 14 when I start it up only the front turbo spins freely at idle the rear one is hard to turn
the oil starvation will flog the turbo so the wheel will come into contact with the housing, if you disconnect the oil feed off the rear turbo and start it up you'll prob see no oil come out or the odd drop, you'll have to pull it apart and check and clean everything
If oil feedline blocks then it will seize while drain blocks will cause turbo to leak oil from all seals. It looks like the feed is blocked. Check the line and drill out the oil restrictor in its fittings.
wont be oil drain, its 4x the size of the feed.
feed will be blocked, meaning there is gunk elsewhere in the system most of the time... cause if there wasn't - how can it be blocked?
No I've got it all worked out if the turbo was seizing it wouldn't make boost its only making 0.6 bar so I'd say it's leaking somewhere one of the pipes meant to be 1 bar And now it's smoking like a bitch on boost I compression tested it and my results where this 50 55 75 100 100 125
Im sorry Ash, I've tried to stay out of this thread.
Your compression is wwwwwaaaaaayyyyyy f**ked.
Your motor has most likely sucked 1 of the 3 turbo's you have gone through.
You say you have it all figured out? I dont think you do. You need to go and buy another motor from the wreckers, this time you need to
  • Make sure you have a good fuel pump
  • Make sure you have working turbo's
  • Make sure you compression test the motor prior to dropping it in
  • Go and get a tune (for the love of god)
  • Don't come on here and ask for advice then turn around and say NO I have it all worked out. (very frustrating when you offer advice and it gets thrown in your face!)
So you had the same problem back in July? Or is this a new compression problem?
http://www.skylinesaustralia.com/forums/topic/404483-rb26-melting-pistons/
If it's a NEW compression problem i would suggest
1. Getting a better tune
2. Learning how to drive
3. Selling the car all together
after reading some of your posts I have to ask, how exactly did you go about doing the comp test ?
you say the rear turbo is the one that keeps blowing but the front 3 cylinders have the lower comp
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
