Hey guys,
After recently purchasing my stagea, with an aftermarket kit/skirts, lowered on nismo springs, ive come to realise how stupidly hard its going to be going anywhere. (Maccas is now off the cards as the stagea wont get in their driveway!)
Ive decided to start looking into a fully engineered airbag suspension kit.
Now, the issue im facing is that no one knows wtf a stagea is, let alone if theres an airbag kit suitable for it. I Hear there are alot of similarities in the stagea to other nissans (V35 mainly) Does anyone know what the suspension setup is like? (Im aware its springs/struts allround anything past that i have no idea)
ive spoken to a guy on the central coast (nsw) who does airbag suspension for showcars and he asked me to take heaps of photos of how the car sits now and what the suspension is like currently. so im yet to take photos and send them up to him but i figured id ask first to see if anyone can shed any light on the matter. i will be updating this thread with my progress but any tips would be greatly appreciated!
If i do choose to go ahead with the install (Set a budget of $5500) watch this space!
https://www.sau.com.au/forums/topic/409053-m35-airbag-suspension/
Im really only toying with the idea at the moment, but in order to make a decision i need a little more information on the matter, ive heard of people bagging their accords for little over $3k, aware the job may have to be a custom job, ive allowed a little more for the job.
p.s. im 21, currently living at home, no expenses, little responsobility, May aswell, right?
If you can't get into Maccas with nismo springs, your doing it wrong. How much did you chop off the bloody things?
IMO, let the accords/lebspecs have their airbags. Instead budget fora turbo rebuild, because it will go eventually, and power/handling improvements, and a nice set of genuine rims.
Its the bloody Gialla(Galah) Front bar it sticks out a good bit from the front of the car...
Just do it bro, that's exactly what customising is about, doing shit your way and your styles.
Should be easy enuff, go see a mini truck bagger, there are some excellent units out there, you will probably need custom inserts to match your chassis pick up points in the rear, the fronts would be a bit different as they are struts. Just make sure you get bags with damper capability, but the bagman will know if he's any good.
The $3k++ can be used wisely elsewhere on the car that will bring you more pleasure and rewards....
Japanese laws regading the 'height' of your car relate to the chassis and what hangs off it from an 'engineering' perspective ( exhaust, etc ) - so, as a result, they design body kits which make the car 'look' really low. a la kenstyle, Galia, etc. the car isnt lowered, the body kit is. Nightmare. And I completely empathise with it!
'Bold world' (Japanese company) have an air suspension kit (more than one actually) so if you're serious about it I'd chase them up first up.
Any contact details for bold world? The google machine seems to be broken, and im not very good at japanese >.<
  • 4 years later...
UAS (Ultimate Air Suspension) in the US do air bags that replace your spring on standard struts or coilovers. This would be the easiest route to go on the front as it keeps everything in the standard spot.
https://www.universalair.com/Aero-Sport-By-Universal-Air-p/02-st-sb-14.htm
Then for the rear, you would put these in but they look like they require some chassis drilling to hold the top and bottom plates.
https://www.universalair.com/Air-House-2-By-Universal-Air-p/02-2600.htm
And finally a whole management kit to run the show depending on if you want front and back control or all four corners control.
https://www.universalair.com/category-s/108.htm
I'm no expert on the subject, but IMO this is easily doable for the weekend garage warrior with guides found online and troubleshooting.
  • Like 2
  • 1 month later...
On 14/06/2017 at 9:07 AM, Sack87 said:
Very helpful.  Thanks heaps.  I would love to see the setup in "MrM35" Stagea.  I have only seen exterior stance photos?
  • Like 1
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
