Hi guys,
Am chasing after some new tyres as the ones i have are rock hard compound, as now SLY is a weekend car am chasing after something nice and soft so i can give it a bit without slipping whilst driving my car in my private car park.
I have spoken to some guys and need advice these are the 2 I have been offered and need your thoughts:
1. i think it's kumho supra ecsta - 255/40/r17 ok i have these offered to me at $240 each are these good tyres for $$$ need something soft and grip a bit better.
2. federal - v rated 255/40/r17 have these offered to me at $207 each, same reasons as to why i need them, something soft and gives me good launch and grip through gears.
I have done a search in the tyre section of forums on these two but not much help.... any of you guys able to help me on the individual tyres?
I am trying to keep my budget to $200 per tyre as in the next couple of months $$$ will be goin elsewhere....
Thanks in advance guys!
https://www.sau.com.au/forums/topic/40906-tyres-federal-or-kumho/
I have the Kumho Ecsta 255/40/17 on the rear of my car, good summer tyres because they are quite a hard compound but in the wet ............. they are like driving around on bars of soap, no traction at the rear and bad understeer on the front, I have done about 15 000K's on them and the rears have about 5000k max left in them.
Thanks R33 Impul - Hmmmm so a no go on them then by the sounds of it..... still need a bit of traction i guess in the wet...... and only last 20,000 k, not very long really, the ones i have on the rear have done 30,000 and prob still have about 10,000 left to go but very vig traction issues with them, Dunlop Le mans 602 i think they are.... bloody hard compoud so not much grip :-(
Anyone had and luck with the federal ones??
im finding same problem .... mine have done about 15,000 now as well and i think i already have "eggs" in them and they are sounding really noisy on the road..... i dont think they are going to see this year out :thumbsup:
And yes im starting to find traction a problem too ...... good tyre when new but seem to be wearing rather quick. :)
I have the Kumho Ecsta Supra's on my 34...were on there when i bought the car... Done close to 30k kay's on them and have found them good all-round tyre...rears are just about shot but fronts still good...would get them again as very good value for money...but then again i drive like grandpa :D
i have ecsta supras on my NA :D
theyre good, done about 15 thousand km's on them since january when i got them... and the rear ones got worn a bit, front are fine so ive rotated them... but yeah... so far so good they seem to be a very grippy tyre. oh and yeah, my driving has been a little... harsh.. which is bad for tyres. :)
i am learning a very expensive lesson.... i have to start driving like a granny... well ... most of the time :)
Rob I'd say the Corsa rates over the Nero.
But for average road user who wants high grip i'd recommend the Bridgestone RE540 or the RE55 TT(middle range compound heaps up nicely and then grip all day).
With any high grip tyre don't expect much tread to be left on the rears anyway when i used to run 540's and kuhmo's on my ute on the front they'd last for ever
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
