hey fellas going to be doing a turbo swap on my 33 this saturday, and im after advice on how to get it off with out breaking any bolts or studs!
any tips for me here? im going to spray a ton of super release on every bolt every night until saturday morning.
but apart from that im stumped!
https://www.sau.com.au/forums/topic/409061-advice-on-turbo-bolts/
Strongly advise you to take off the manifold and change all the studs at the same time.
You are highly likely to find there are 1-2 broken already as it is... So better to spend extra and do it now, rather than deal with it later on especially if you are upgrading the turbo which will be more heat and so on.
To note: you will break some studs in the head. Not many people get them all out without breaking any. In this instance call the "thread doctor". There is usually one guy in each state and getting them to do it is far cheaper/easier than trying to DIY for that particular job.
thanks every one, may just change the dump.frobt pipe on saturday then, and do the turbs when i have more time,,,, cant risk not finishing it saturday as its going in for work wednesday.
What turbo u putting in it platts...gimme a call if you want a hand mate, just book thread doctor in advance, you will need him..i didnt even undo my manifold bolts i let him do it, still broke 5 only 2 needed drilling though..dont think he works Saturdays either..
IF you end up snapping a few bolts on the turbo manifold, pray that it's not flush.
If there is some bolt thread still sticking out, a method that my mate and I came up with is to angle grind two sides of the bolt to make it both sides have a flat surface. Then spray the sht out of it with WD40 and wait for a bit, before using an adjustable wrench to twist back and forth. Eventually you'll be able to twist the bolt out.
I found the problem not to be the bolt but the turbo housing. With the stock dump pipe, the flange is a lot thicker than an aftermarket one, so that means that during the 15+ years that the bolt was on, rust has actually settled on the reverse side where there is space in the thread hole. Obviously if the aftermarket dump has a thinner flange, the bolt that you'll be using will travel further into the housing, which will be caught in the rust and seize. After that that's when snap bolt situations come into play.
ball sacks!
its just another standard turbs for the min in a lot better condition than mine, a 45v3 but like i said that can wait until mine blows up!
im strappin a new dump pipe/ front pipe bellmouth on there tho so feel free to head over buddy!
thinkin turbodragon might come down as well, he seemed pretty keen so ill grab some beers!
cool, ill keep all this in mind.
fellas overwhelmed by the help on this, had started to loose faith with sau, alot of wankrs being wankrs! but youve pulled me back round fellas.
forgot im puttin in a catch can and a metal intake at the same time.
bring your 33 round mate! then when andrew turns up in his we will have a little race thru the housing estate.
(joke. street racing is bad and illegal)
(but fun)
because
just spot the ones that work on their cars and their mates cars vs. those who pay people to do everything, even to change their light bulbs.
man with penis vs. man with vagina.
when you start undoing the bolts and it snags, just slowly do them back in and then back out, don't force them they will snap like what Ph@t-G did when I took off for a few hours that day lol....
and lucky that lancer motor was around, free bolts LOL
because
LOVE IT!
hey, just thinking if i snap some bolts changing the dumper, can i just replace them with stainless nuts and bolts?
have heard stainless is not good on exhaust connections, tends to gall. Hi tensile loses it's hi tensile-ness too once heated, just new steel bolts and nuts with a burred flange head will be fine.
Definitely change the studs on exhaust manifold, as said by others, if some not already broken then soon will, replace with new.
If you take dump and front pipe off as one piece it should be fine..
sounds like a plan, you up for it davey? few beers/bourbons/rums init for ya?!
not that ill need much help, just get bored talkin to my self. ha!
cheers buddy!
yea ill replace the manifold and or the bolts a little later on, gonna leave my turbo on for now until it blows, then swap em over and send the knackered one for a hi-flow!
the man is right on the money!
This thread might also give you a bit of heads up before you start working. At least this way you know what to expect in terms of procedures.
http://www.skylinesaustralia.com/forums/topic/129061-installing-3-dumpfront-and-high-flow-cat/
Good luck with it man and hope you don't snap bolts!
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
