hey fellas going to be doing a turbo swap on my 33 this saturday, and im after advice on how to get it off with out breaking any bolts or studs!
any tips for me here? im going to spray a ton of super release on every bolt every night until saturday morning.
but apart from that im stumped!
https://www.sau.com.au/forums/topic/409061-advice-on-turbo-bolts/
Strongly advise you to take off the manifold and change all the studs at the same time.
You are highly likely to find there are 1-2 broken already as it is... So better to spend extra and do it now, rather than deal with it later on especially if you are upgrading the turbo which will be more heat and so on.
To note: you will break some studs in the head. Not many people get them all out without breaking any. In this instance call the "thread doctor". There is usually one guy in each state and getting them to do it is far cheaper/easier than trying to DIY for that particular job.
thanks every one, may just change the dump.frobt pipe on saturday then, and do the turbs when i have more time,,,, cant risk not finishing it saturday as its going in for work wednesday.
What turbo u putting in it platts...gimme a call if you want a hand mate, just book thread doctor in advance, you will need him..i didnt even undo my manifold bolts i let him do it, still broke 5 only 2 needed drilling though..dont think he works Saturdays either..
IF you end up snapping a few bolts on the turbo manifold, pray that it's not flush.
If there is some bolt thread still sticking out, a method that my mate and I came up with is to angle grind two sides of the bolt to make it both sides have a flat surface. Then spray the sht out of it with WD40 and wait for a bit, before using an adjustable wrench to twist back and forth. Eventually you'll be able to twist the bolt out.
I found the problem not to be the bolt but the turbo housing. With the stock dump pipe, the flange is a lot thicker than an aftermarket one, so that means that during the 15+ years that the bolt was on, rust has actually settled on the reverse side where there is space in the thread hole. Obviously if the aftermarket dump has a thinner flange, the bolt that you'll be using will travel further into the housing, which will be caught in the rust and seize. After that that's when snap bolt situations come into play.
ball sacks!
its just another standard turbs for the min in a lot better condition than mine, a 45v3 but like i said that can wait until mine blows up!
im strappin a new dump pipe/ front pipe bellmouth on there tho so feel free to head over buddy!
thinkin turbodragon might come down as well, he seemed pretty keen so ill grab some beers!
cool, ill keep all this in mind.
fellas overwhelmed by the help on this, had started to loose faith with sau, alot of wankrs being wankrs! but youve pulled me back round fellas.
forgot im puttin in a catch can and a metal intake at the same time.
bring your 33 round mate! then when andrew turns up in his we will have a little race thru the housing estate.
(joke. street racing is bad and illegal)
(but fun)
because
just spot the ones that work on their cars and their mates cars vs. those who pay people to do everything, even to change their light bulbs.
man with penis vs. man with vagina.
when you start undoing the bolts and it snags, just slowly do them back in and then back out, don't force them they will snap like what Ph@t-G did when I took off for a few hours that day lol....
and lucky that lancer motor was around, free bolts LOL
because
LOVE IT!
hey, just thinking if i snap some bolts changing the dumper, can i just replace them with stainless nuts and bolts?
have heard stainless is not good on exhaust connections, tends to gall. Hi tensile loses it's hi tensile-ness too once heated, just new steel bolts and nuts with a burred flange head will be fine.
Definitely change the studs on exhaust manifold, as said by others, if some not already broken then soon will, replace with new.
If you take dump and front pipe off as one piece it should be fine..
sounds like a plan, you up for it davey? few beers/bourbons/rums init for ya?!
not that ill need much help, just get bored talkin to my self. ha!
cheers buddy!
yea ill replace the manifold and or the bolts a little later on, gonna leave my turbo on for now until it blows, then swap em over and send the knackered one for a hi-flow!
the man is right on the money!
This thread might also give you a bit of heads up before you start working. At least this way you know what to expect in terms of procedures.
http://www.skylinesaustralia.com/forums/topic/129061-installing-3-dumpfront-and-high-flow-cat/
Good luck with it man and hope you don't snap bolts!
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
