Get out the sound meter :D
Your probably right about the acceptable level of noise from a whats legal perspective, but I drive it around with it shut, and only open it for track or big street runs.
They do flow, you were probably asking too much of a dual muffler 3.5" system really as you can never have such quiet and not have minor restriction at that size, for your power/flow levels. E85 just needs a bit more of everything - and certainly costly.
The first muffler on my setup was diagonal orientated with a perforated core, so when the air comes in it then hits next bend with the perforations in the side wall creating unwanted turbulence and vortices I suspect. In regards to a straight through muffler it needs to be dead straight, and not with bends inside. It's ok to a degree with straight smooth pipe, but with the muffler holes, definitely straight. This is pretty much what I believe to be creating my issue, especially with the E85 and more HP. 2 LBS of boost more from this relief of back pressure in my exhaust just goes to show how much it was having an effect. I would have liked to go with a big 4" too Ash, but for what I want out of it, I didn't really want to spend that much more. I would have had to do front pipes too, which isn't cheap at that size.
Yeah my tri-pass radiator was sensational, 5 laps and tip top water temps but then I wasn't using E85 or as much boost, tyres would be off before the cooling system had an argument.
  • Replies 80
-9s were all over by around 7500rpm with the same motor config
Is there much difference with the -9's and gt-ss? On my old car with stock cams and heads, my car kept making more power past 7,500 rpm with gt-ss turbos.
http://i49.tinypic.com/2cgbyv5.jpg
Edited by topher_
Whats opinions on HKS split dumps? Is it worth the hassle to change to a set of Midori ones. Also thinking about changing the mines front pipe to something a little bigger as well..
I'm aiming to get into the high 300kw area.
Have made over 400 with them...but it ain't the most efficient way of doing it.
Well that's good enough for me. There obviously not the best out there but will do the job. Think I'll save changing em out for when the motor is out.
Money better put towards some twin 3" into 3.5" front pipes.
Looking for these too but most tend to be 2.75 into 3 or 3 into 3.
Does anyone know a supplier in melbourne
What size are the racepace front pipes?
And do they have equal length pipes before they merge?
Twin 3 inch merging into a 3.5 or 4 inch. Take your pick. (Why you wouldn't go 4 inch is beyond me).
Forget the japanese junk.... well worth the cash.
You always get used to the power.
Plus you'd still need to do transfer case, front/rear diff, suspension. They make the biggest difference dollar vs gains IMO over power/rebuild - just there is 10k on its own. So add in another 15k for the motor and everything and you've done 25k there. Hence why my GTR was such a bargin really @ 30k, and sold easily :)
can you tell me more about the transfer case mod please???
search drivetrain section - all in there.
They are identical.
If the graph you linked didn't end @ 7400rpm, you'd see torque fall off even harder than it already has. Boost would be the same as well.
Yeah sure more RPM it might make a little bit more power (10kw), but the turbos are pretty much off the efficiency, falling harder and harder off from boost/torque the more RPM you ask - so you gain nothing by taking it past there. Better off to change gear and fall back into the 6000rpm area.
My comment about it being "all over" by 7500rpm is that both boost and torque have well and truly fallen off by then. Where -5s will keep pressing till 8500rpm on a 2.6 no problem which is a solid 1000rpm more and they aren't falling over.
I've been doing a bit of research here and there, and my exhaust I think is just at maximum capacity for my setup, it seems on 98 and under 400kw, bloody awesome piece of kit. I would have liked to go the RP 4" version.
After researching some more on the -10's topic too, I think I'll stick with the -5's and be happy with what I've got.
A new set of semi's, a brake bleed, and I'll be all good to try the QR clubsprint record again. It's just QR is so setup for big HP over handling, hence the reason I was thinking -10's. Although I'm only 6/10's off the club-sprint record holder, and he is running an R32 with 50kw more. That was my first track day out there with only 15 laps, so maybe a bit more drive time might help.....lol.
-5's seem as they are pretty much one of the best turbo choices for track duties, hands down. The -7's seem good to for a bit less power and super response.
    • And half of them have been converted to turbos.
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
