Get out the sound meter :D
Your probably right about the acceptable level of noise from a whats legal perspective, but I drive it around with it shut, and only open it for track or big street runs.
They do flow, you were probably asking too much of a dual muffler 3.5" system really as you can never have such quiet and not have minor restriction at that size, for your power/flow levels. E85 just needs a bit more of everything - and certainly costly.
The first muffler on my setup was diagonal orientated with a perforated core, so when the air comes in it then hits next bend with the perforations in the side wall creating unwanted turbulence and vortices I suspect. In regards to a straight through muffler it needs to be dead straight, and not with bends inside. It's ok to a degree with straight smooth pipe, but with the muffler holes, definitely straight. This is pretty much what I believe to be creating my issue, especially with the E85 and more HP. 2 LBS of boost more from this relief of back pressure in my exhaust just goes to show how much it was having an effect. I would have liked to go with a big 4" too Ash, but for what I want out of it, I didn't really want to spend that much more. I would have had to do front pipes too, which isn't cheap at that size.
Yeah my tri-pass radiator was sensational, 5 laps and tip top water temps but then I wasn't using E85 or as much boost, tyres would be off before the cooling system had an argument.
  • Replies 80
-9s were all over by around 7500rpm with the same motor config
Is there much difference with the -9's and gt-ss? On my old car with stock cams and heads, my car kept making more power past 7,500 rpm with gt-ss turbos.
http://i49.tinypic.com/2cgbyv5.jpg
Edited by topher_
Whats opinions on HKS split dumps? Is it worth the hassle to change to a set of Midori ones. Also thinking about changing the mines front pipe to something a little bigger as well..
I'm aiming to get into the high 300kw area.
Have made over 400 with them...but it ain't the most efficient way of doing it.
Well that's good enough for me. There obviously not the best out there but will do the job. Think I'll save changing em out for when the motor is out.
Money better put towards some twin 3" into 3.5" front pipes.
Looking for these too but most tend to be 2.75 into 3 or 3 into 3.
Does anyone know a supplier in melbourne
What size are the racepace front pipes?
And do they have equal length pipes before they merge?
Twin 3 inch merging into a 3.5 or 4 inch. Take your pick. (Why you wouldn't go 4 inch is beyond me).
Forget the japanese junk.... well worth the cash.
You always get used to the power.
Plus you'd still need to do transfer case, front/rear diff, suspension. They make the biggest difference dollar vs gains IMO over power/rebuild - just there is 10k on its own. So add in another 15k for the motor and everything and you've done 25k there. Hence why my GTR was such a bargin really @ 30k, and sold easily :)
can you tell me more about the transfer case mod please???
search drivetrain section - all in there.
They are identical.
If the graph you linked didn't end @ 7400rpm, you'd see torque fall off even harder than it already has. Boost would be the same as well.
Yeah sure more RPM it might make a little bit more power (10kw), but the turbos are pretty much off the efficiency, falling harder and harder off from boost/torque the more RPM you ask - so you gain nothing by taking it past there. Better off to change gear and fall back into the 6000rpm area.
My comment about it being "all over" by 7500rpm is that both boost and torque have well and truly fallen off by then. Where -5s will keep pressing till 8500rpm on a 2.6 no problem which is a solid 1000rpm more and they aren't falling over.
I've been doing a bit of research here and there, and my exhaust I think is just at maximum capacity for my setup, it seems on 98 and under 400kw, bloody awesome piece of kit. I would have liked to go the RP 4" version.
After researching some more on the -10's topic too, I think I'll stick with the -5's and be happy with what I've got.
A new set of semi's, a brake bleed, and I'll be all good to try the QR clubsprint record again. It's just QR is so setup for big HP over handling, hence the reason I was thinking -10's. Although I'm only 6/10's off the club-sprint record holder, and he is running an R32 with 50kw more. That was my first track day out there with only 15 laps, so maybe a bit more drive time might help.....lol.
-5's seem as they are pretty much one of the best turbo choices for track duties, hands down. The -7's seem good to for a bit less power and super response.
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
