Opinions Regarding Garett 2860 -5S On An Rb26
R33-RB26DETT
 Share
I've been doing a bit of research here and there, and my exhaust I think is just at maximum capacity for my setup, it seems on 98 and under 400kw, bloody awesome piece of kit. I would have liked to go the RP 4" version.
After researching some more on the -10's topic too, I think I'll stick with the -5's and be happy with what I've got.
A new set of semi's, a brake bleed, and I'll be all good to try the QR clubsprint record again. It's just QR is so setup for big HP over handling, hence the reason I was thinking -10's. Although I'm only 6/10's off the club-sprint record holder, and he is running an R32 with 50kw more. That was my first track day out there with only 15 laps, so maybe a bit more drive time might help.....lol.
-5's seem as they are pretty much one of the best turbo choices for track duties, hands down. The -7's seem good to for a bit less power and super response.
If you go -10s you will be slower around the track.. Keep the 5s
  • Replies 80
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
