Ages ago i did the manual conversion on my R34 using R33 parts.
The speedo sensor plug was different, i purchased a R34 Speedo Sensor recently to replace this but it appears the plugs been damaged so i dont know which way it goes, if i put the two wires the wrong way around is the signal going to damage anything?
Goes in for a tune soon and needs the speed signal, if i cant get it working prior i'll just get the workshop to do it, but would rather do it myself instead of paying them.
Cheer's!
https://www.sau.com.au/forums/topic/409086-speedo-sensor-wiring/
Cheer's!
No the signal will not damage anything. Both wires should output a pulse from the sender but one goes to ground on the loom end.
I'm fairly sure you can put the wires either way around and it will work but if you put a deutch plug there you can just swap them if it doesn't.
  • 2 months later...
Thread bump.
Where is the speedo sender on a S2 R33 GTS-t?
I am having issues with an intermittent speedo that wasn't fixed with a cluster change so I am guessing there might be an issue with the sender or plug.
Drivers side of the gearbox right near the crossmember
Has anyone had a faulty sender causing intermittent speedo issues?
I cleaned the plug with contact cleaner and had a quick look and couldn't see anything obvious. I don't think it is likely that both speedos are faulty so it seems the issue is between the sender and the dash or the sender itself.
The sender produces its own signal so you can test it at every point in the loom. We usually trace it back to the section of the harness just beneath the fuse box and break it open there. Splice in with our scope and test the signal. If the signal is good, the dash is going to be the problem or the wire under the dash behind the cluster.
9/10 times it's the cluster though. The heat f**ks them up. Borrow a mates, swap it out and see if it fixes your problem
I bought another cluster from another SAU member and the speedo has the same issue.
The advice from Andy at ASR is that he has only ever seen cluster issues, never a sender. When the car gets run for >30 mins usually it comes good so it is temperature dependent.
I guess I will have to get someone to trace the wiring to where the fault is.
  • 4 weeks later...
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
