Ages ago i did the manual conversion on my R34 using R33 parts.
The speedo sensor plug was different, i purchased a R34 Speedo Sensor recently to replace this but it appears the plugs been damaged so i dont know which way it goes, if i put the two wires the wrong way around is the signal going to damage anything?
Goes in for a tune soon and needs the speed signal, if i cant get it working prior i'll just get the workshop to do it, but would rather do it myself instead of paying them.
Cheer's!
https://www.sau.com.au/forums/topic/409086-speedo-sensor-wiring/
Cheer's!
No the signal will not damage anything. Both wires should output a pulse from the sender but one goes to ground on the loom end.
I'm fairly sure you can put the wires either way around and it will work but if you put a deutch plug there you can just swap them if it doesn't.
  • 2 months later...
Thread bump.
Where is the speedo sender on a S2 R33 GTS-t?
I am having issues with an intermittent speedo that wasn't fixed with a cluster change so I am guessing there might be an issue with the sender or plug.
Drivers side of the gearbox right near the crossmember
Has anyone had a faulty sender causing intermittent speedo issues?
I cleaned the plug with contact cleaner and had a quick look and couldn't see anything obvious. I don't think it is likely that both speedos are faulty so it seems the issue is between the sender and the dash or the sender itself.
The sender produces its own signal so you can test it at every point in the loom. We usually trace it back to the section of the harness just beneath the fuse box and break it open there. Splice in with our scope and test the signal. If the signal is good, the dash is going to be the problem or the wire under the dash behind the cluster.
9/10 times it's the cluster though. The heat f**ks them up. Borrow a mates, swap it out and see if it fixes your problem
I bought another cluster from another SAU member and the speedo has the same issue.
The advice from Andy at ASR is that he has only ever seen cluster issues, never a sender. When the car gets run for >30 mins usually it comes good so it is temperature dependent.
I guess I will have to get someone to trace the wiring to where the fault is.
  • 4 weeks later...
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
