Ages ago i did the manual conversion on my R34 using R33 parts.
The speedo sensor plug was different, i purchased a R34 Speedo Sensor recently to replace this but it appears the plugs been damaged so i dont know which way it goes, if i put the two wires the wrong way around is the signal going to damage anything?
Goes in for a tune soon and needs the speed signal, if i cant get it working prior i'll just get the workshop to do it, but would rather do it myself instead of paying them.
Cheer's!
https://www.sau.com.au/forums/topic/409086-speedo-sensor-wiring/
Cheer's!
No the signal will not damage anything. Both wires should output a pulse from the sender but one goes to ground on the loom end.
I'm fairly sure you can put the wires either way around and it will work but if you put a deutch plug there you can just swap them if it doesn't.
  • 2 months later...
Thread bump.
Where is the speedo sender on a S2 R33 GTS-t?
I am having issues with an intermittent speedo that wasn't fixed with a cluster change so I am guessing there might be an issue with the sender or plug.
Drivers side of the gearbox right near the crossmember
Has anyone had a faulty sender causing intermittent speedo issues?
I cleaned the plug with contact cleaner and had a quick look and couldn't see anything obvious. I don't think it is likely that both speedos are faulty so it seems the issue is between the sender and the dash or the sender itself.
The sender produces its own signal so you can test it at every point in the loom. We usually trace it back to the section of the harness just beneath the fuse box and break it open there. Splice in with our scope and test the signal. If the signal is good, the dash is going to be the problem or the wire under the dash behind the cluster.
9/10 times it's the cluster though. The heat f**ks them up. Borrow a mates, swap it out and see if it fixes your problem
I bought another cluster from another SAU member and the speedo has the same issue.
The advice from Andy at ASR is that he has only ever seen cluster issues, never a sender. When the car gets run for >30 mins usually it comes good so it is temperature dependent.
I guess I will have to get someone to trace the wiring to where the fault is.
  • 4 weeks later...
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
