Ages ago i did the manual conversion on my R34 using R33 parts.
The speedo sensor plug was different, i purchased a R34 Speedo Sensor recently to replace this but it appears the plugs been damaged so i dont know which way it goes, if i put the two wires the wrong way around is the signal going to damage anything?
Goes in for a tune soon and needs the speed signal, if i cant get it working prior i'll just get the workshop to do it, but would rather do it myself instead of paying them.
Cheer's!
https://www.sau.com.au/forums/topic/409086-speedo-sensor-wiring/
Cheer's!
No the signal will not damage anything. Both wires should output a pulse from the sender but one goes to ground on the loom end.
I'm fairly sure you can put the wires either way around and it will work but if you put a deutch plug there you can just swap them if it doesn't.
  • 2 months later...
Thread bump.
Where is the speedo sender on a S2 R33 GTS-t?
I am having issues with an intermittent speedo that wasn't fixed with a cluster change so I am guessing there might be an issue with the sender or plug.
Drivers side of the gearbox right near the crossmember
Has anyone had a faulty sender causing intermittent speedo issues?
I cleaned the plug with contact cleaner and had a quick look and couldn't see anything obvious. I don't think it is likely that both speedos are faulty so it seems the issue is between the sender and the dash or the sender itself.
The sender produces its own signal so you can test it at every point in the loom. We usually trace it back to the section of the harness just beneath the fuse box and break it open there. Splice in with our scope and test the signal. If the signal is good, the dash is going to be the problem or the wire under the dash behind the cluster.
9/10 times it's the cluster though. The heat f**ks them up. Borrow a mates, swap it out and see if it fixes your problem
I bought another cluster from another SAU member and the speedo has the same issue.
The advice from Andy at ASR is that he has only ever seen cluster issues, never a sender. When the car gets run for >30 mins usually it comes good so it is temperature dependent.
I guess I will have to get someone to trace the wiring to where the fault is.
  • 4 weeks later...
    • Hello First, I apologize if this is not the correct forum. Let me know and I will move it to the correct one. I'm having a problem with the tachometer on my Skyline R33 with an RB25DET Neo engine. I'll tell you from the beginning. I'll tell you from the beginning. I have the RB25DET Neo engine installed in a Nissan Patrol GU, with a Link G4X control unit specifically for that engine,  and I have fitted a Skyline R33 tachograph to the original GU dashboard, but it doesn't work properly. I have the tachometer connected to the positive and negative terminals of the GU panel's wiring, and the signal cable is connected directly to the ECU output pin, but the rpm fluctuates widely. Can anyone tell me if the output signal from an R33 ECU is the same as the output signal from an R34 ECU, or if the voltage and signal type are different? Regards and thanks.
    • I guess it was the thought about "Oh if I were to drive this everyday". Then no, SL500 I wouldn't really consider lmao.
    • Yeah actually really fair point. Idk what I was thinking when looking at the SL500. Now that I think about it, I feel like I would have more enjoyment out of a shitbox that I would need to repair than some fancy merc. Although I must admit the SL500 does look quite nice. My bad hahaha.
    • 100% Also "Not wanting to spend money" is THE WORST IDEA IMAGINABLE when coming to a project car of any kind. They EXIST to BURN MONEY. Sure, gas money is a thing. A stock car with the worst fuel economy ever sold would probably be cheaper than modifying a car with FREE petrol for the life of your ownership of it, lol.
    • Amount of time you're being observed by law enforcement is so minute, that you could be a dumb shit 90% of your driving time, and never lose a demerit. You could also be the best driver ever and still get hit with a fine.   When you realise how quickly everything turns from "Wee, we're having fun!" To "oh f**k oh f**k oh f**k", you start to realise the only way to be a good driver, is to not be doing anything dumb or unexpected by normies on the road. You want to go fast, go to the track. Someone there in a 1990s slow POS will also show you how bad of a driver you are as they lap 10 seconds per lap quicker than you can in a car that should be considerably faster.
