tried looking on the DBA website but tehy dont list the v35.
are teh 350z rear rotors the same?
or is there a differnt part number im looking for?
does the brembo brake option make a differance to rear rotors?
same deal with rear pads, 350z?
cheers
Edited by GeNOS
https://www.sau.com.au/forums/topic/409099-rear-rotor-part-number/
Rear Rotor
DBA 574 DBA
03 ~ 05 Touring Model OD - 292 DBA 574S
Street Series T2 Slot
DBA 574SL
Street Series Slotted Left Hand
DBA 574SR
Street Series Slotted Right Hand
DBA 574X
Street Series Cross Drilled Slotted
DBA 4601 DBA
03 > Track Model OD - 322 DBA 4601S
4000 Series T3 Slot
DBA 4601SL
4000 Series Slotted Left
DBA 4601SR
4000 Series Slotted Right
DBA 4601XS
4000 Series Crossdrilled Slotted
Same as 350z. Touring model is non brembo, track version is brembo. sorry about the format- it was just a copy paste off the online catalogue. have a look if its not clear.
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
